Pages: 1 2 Next
CentiLeo for 3ds Max 0.586 available - speedup 2x to up to 10x, added many new shaders and emission
Administrator  Posts: 897
Nov 18, 2019 20:00
Finally we are releasing the 0.58 update of CentiLeo for 3ds Max 2014-2020. We appology for not updating so long, as we have radically changed the architecture to reduce the noise, improve speed and flexibility. It was a complex atomic work. The current release unites 0.56, 57 and 58 updates we had for CentiLeo +Cinema 4D plugin.
However, we have made great impovements, see the changelog and download for tests.
Download link: http://centileo.com/download/
Change Log: cntlmax 0.586 alpha (2020 January 30)
[cntlmax] Fixed problems when 3ds Max UI scheme is saved
[cntlmax] Fixed some mesh normal artifacts in rare cases
Change Log: cntlmax 0.585 alpha (2020 January 29)
[core] 5-10% rendering speedup
[core] Fixed shadow catcher weights in case of many light sources (makes shadows of different intensity per light source on the Matte/Shadow Catcher object).
[core] Fixed shadow artifacts in case of very small area lights.
[core] Bitmap file paths now support Unicode strings (not just English).
[core] Fixed camera Auto Focus in IPR ([AF] button).
[core] CentiLeo updated to CUDA 10.2.
Attention! Must Upgrade to:
Change Log: cntlmax 0.584 alpha (2019 December 31)
[core] Fixed z-fighting render artifacts for coplanar polygons in the scene, precision is improved.
[core] Fixed few rare crash-bugs.
[cntlmax] Installation instructions are changed a bit, read them again!
Change Log: cntlmax 0.583 alpha (2019 December 6)
[cntlmax] Fixed broken GUI layout for increased windows font size and high resolution monitors.
Change Log: cntlmax 0.582 alpha (2019 November 29)
[cntlmax] Added Ramp shader that colorizes the input b/w texture with other colors. The nodes of our ramp shader can be textured.
[cntlmax] Fixed scene units representation in all CentiLeo materials, shaders and lights.
[cntlmax] Focus distance in render settings can be animated.
[cntlmax] Initial 3ds Max Physical camera support (DOF focus distance, aperture size, bokeh). Next will add support for other things of Physical camera.
Change Log: cntlmax 0.581 alpha (2019 November 18)
Speedup
[core] Rendering speedup from 2x to up to 10x:
-Render iterations are around 2x faster almost always (base speedup);
-Render iterations become smarter and reduce the noise better for global illumination, in some cases it is required 2-4x less iterations to get same noise level as before. These improvements are best visible for interiors and night scenes especially for regions with dominated global illumination and lack of direct lighting.
-Mesh lights with complex shapes (more than few polygons) generate 3-4x less noise than before.
-The new algorithm should be always better and more robust than the previous one (less noise per iteration and faster iteration time).
-And there is no cache, no blur, no aditional settings, no additional memory consumption
Shader improvements
[core] New UVW Projection node supporting up to 4 UV mesh channels, spherical, cylindrical, cubic, flat, flat side, spatial and XYZ texture mapping coordinates. Texture coordinate system can be further manipulated (offset, scale, rotation) in the similar way to UVW Map modifier of 3ds Max. Offset, scale and rotation can be textured. Procedural texture coordinates are currently based on the object instances where material is assigned.
[core] New UVW Transform node which performs further manipulations on texture coordinates (UVW Projection can be an input for UVW Transform). Supported manipulations are offset, scale, rotation, pivot, rand offset, repetitions - these parameters can be textured.
[core] Extended CentiLeo Noise shaders with more noise types like Voronoi, Ronk, Ridged Multi-Fractal, etc.
[core] Bump mapping code totally changed (it also changes the look and scale of bump on older scenes). It has higher quality now and better combination with Normal Maps. Normal Maps now have all these flip R/G/B options.
[core] Fixed some problems with liquids inside glass in some modes.
[core] Faster bitmap cache generator (2x faster).
Mesh Lights and Multi-lights
[core] Mesh Lights support. This is implemented with an additional Emission property of CentiLeo material. Supports arbitrary (even out-of-core) geometry shapes for the light sources.
[core] Adaptive Multi Lights 10 times faster rendering for glossy reflection surfaces (faster rendering when there are a lot of light sources and glossy materials). Also bugfixed many issues in this area.
Bugfixes
[core] Fixed Windows 10 memory bug which could cause crashes in scenes with a lot of geometry and textures.
[core] Fixed artifact bug when SSS doesn’t follow motion blur.
[core] Fixed wrong clamping for 16+ bit bitmaps when used for displacement.
[core] Fixed some triplanar mapping artifacts.
[core] Fixed wrong bump mapping over displacement mapping (when bump and displace maps are different).
-Dirt shader;
-Absorption property of material;
-Directional/infinite light source;
-Adaptive noise-based image rendering (where pixels are no longer rendered when specified noise level is reached).
-May not initialize if AMD GPU is in your computer together with NVIDIA GPU.
-Very limited scene converter tool (Multi Sub-Obj Material, 3ds Max Bitmap, only diffuse color and diffuse texture of material are converted to CentiLeo)
Kirill
Edited: Kirgman - Apr 18, 2020 21:37 (Update 0.586 with improvements)
Nov 18, 2019 20:15
Some comparison with the previous version:
1280x720, one GTX1070, 4 iterations (256 samples), some darky interior with 4 lights, HDR and 3 portals.
CentiLeo 0.55 - 328 seconds
CentiLeo 0.58 - 119 seconds and less noise
Yaaaaaaaaaasssssss finally :D .. thanks alot Kirgman testing it right now ..
I noticed i small problem and i hope it is also small to fix. When you open a scene and try the IPR, after that you hit pause in the IPR , closes the IPR window, and render directly after that , the render is black as it renders nothing. and if you try to start the IPR one more time Max crashes .
3dmax 2019 x64, win10, 2X 980tis
I hope it is just a small easy bug to fix.
Best regards
Edited: a1cat cato - Nov 20, 2019 11:45
Nov 20, 2019 13:39
a1cat cato, thanks for bugreport! Looking into that. There is a good collection already of such small little bugs :)
Hi there , hope you all fine guys :D , i thought i found another bug, but it was i simple mistake from my side ;) :oops:.
Thanks a lot guys , i will try to test it more and keep you up to date.
Best regards
Edited: a1cat cato - Nov 24, 2019 20:12
Nov 25, 2019 03:20
Hi, a1cat cato! Which bug? Tell me. Maybe I could describe things better in documentation. Right now integrating Ramp GUI control into the shader and PhysicalCamera to cntlmax. A few days.
Hi dear Centileo devs
Congratulations on the progress made in improving the noise.
I noticed after installing Centileo, Corona render cannot load (MAX 2020)
Mix shader is gone.
Good progress in noiseless renders but after 32 Iteration a simple interior renders appearances very noisy.
some
A few suggestions:
-New technologies like Optix denoiser for unbiased mode can help for noise clean renders.
-CentiLeo is a special engine with potential a Light cache solution for secondary GI can help a lot.
-Ability to add emissive objects in blend light passes.
Nov 28, 2019 19:22
Hi Ali Kavyani, thanks for bugrep!
Mix shader is now Layer shader which is more powerfull multi-layer thing. In default mode it behaves like old Mix shader.
Please show me example picture and tell what light sources, portals and HDRs are there.
Will look at denoisers after couple of other optimizations.
No to Light Cache! Not because of bias, but because of complexity of parameters.
AOVs will be massively updated in a few months.
It looks very strange we have no any shared things with Corona unlike in some past where we both used wxWidgets library. Now we don't use it. Will look again. Windows 10?
Hi Kirill,
Yes, Win 10.
I will post more info about the noise problem.
Corona's problem is strange to me tried on another PC and the same problem.
Nov 29, 2019 20:44
Hi Ali, I currently don't have fresh Corona for tests. Will investigate later. Currenly expect that there is nothing we can do with this. Corona was already known in the past to have influence on our crashes when we used wxWidgets. CentiLeo coexists with other GPU renderers in Max or Cinema. Sometimes both renderer IPRs are opened (in Cinema).
Better tell me about the noisy scenes. If you light with HDR then use portals! They become so much better in latest release.
Nov 29, 2019 20:44
Hi there , sorry to be late i am having some hardware problems :cry:. But i did a test i would like to share with you but i think there is no option to upload here . I don't know how to link images so they appear directly in the post so i uploaded it on imgur.
The drag and drop image worked Thanks :D
Ps: I had problems with the depth of field and took me so long to find the correct values , i wish there was some kind of feed back in the normal view port to choose DOF values quickly.
Unfortunately i can't open the IPR cause it crashes 3DMax, I will try the Physical camera option.
Thanks a lot for the hard work.
Best regards
Edited: a1cat cato - Nov 30, 2019 13:35
Nov 30, 2019 13:26
Hi a1cat cato, you can directly drag & drop your images from your computer to the reply form of this forum and it will be attached. Just below the text edit box there is an area with "Upload images" title.
As for IPR autofocus tool - I will fix it for the next bugfixing update. Btw, you may look into Max Physical camera options, target distance, etc. Soon it will be supported almost completely, Mostly I like tilt options of it.
Another test with the Physical Camera.
As a note for the new users , if you want to use IPR don't pause the IPR then close it . Close it directly without pausing .
- If you open the IPR, let it render , pause it , then close it and try to render a normal render : the render will be black , and if you try to run IPR again max will crash.
the correct way is :
- open IPR , use it as much as you want, and pause/resume it as much as you want. When you are done with it, and want a Full Render, then let it run first then close it from the X button. After that you can render a full normal render .
Of course this is just a workaround until it is fixed ;) :D. Shout out to the dev team :idea:.
Best regards
Edited: a1cat cato - Nov 30, 2019 18:26
Nov 30, 2019 19:38
Btw I tried to fix the bug with IPR - final render conflict. But hasn't reproduced it quickly and released with other fixes. For me the pauses, launches of final render haven't produced the crashes. Note that final render will not start until IPR is closed because we want full resources in either case.
But I will test more on Win10 (because I usually do tests in Win7) and hope to cactch the problem.
Good image! I like them with DoF. Next step is to add SSS for candles. And small fire :idea:
Hi there, another test with SSS ;).
It was difficult to fiddle down a little by little to find good values, but i heard that there will be a new help file with examples, which would be so helpful, so i will be waiting for the next update.
I will keep you up to date guys with the bugs, sorry to be late but i have some hardware problems right now.
Best regards
Edited: a1cat cato - Dec 2, 2019 03:37
Dec 2, 2019 07:37
Hi a1cat cato, a lot nicer! :)
This is diffusion based SSS (but ray traced). It's pretty fast, but not precise on the small details because may them.
As for usability - it's the same as in Arnold or Reshift (tested a year ago). Their documentation may apply for us too.
3 layers which are mixed together. For example to make white you may create one red, another green and another blue. And they will be combined to white. Another way is to make all layers white and it will be the same. To make some color effect from under surface you can make some red channel with larger radius.
There is more precise method (but a bit slower/noiser) - Random Walk SSS, we haven't yet implemented it, but it's in the TODO list.
Will describe such things in manual.
Dec 6, 2019 08:03
Appleseed has random walk implemented, you might want to take a look on their code.
Dec 9, 2019 18:43
Hello Juan! Welcome here and thanks for advice! I know this. The theory and potential samples are known, but the actual port in our software environment can be very-very different. Anyway still need to improve other things before diving into this topic.
Pages: 1 2 Next
