RSS
CentiLeo for Cinema 4D 0.571 available - many additional shader nodes
We now reelease an update CentiLeo 0.57 for Cinema 4D R16-R20. The new release adds flexible UVW Projection, Transform and Distortion shader nodes in the manner of Cinema R20. UVW nodes add a lot of flexibility in combination with Bitmaps. Also added easy to setu[ Flakes and Scratches shader nodes for procedural imperfections. Improved Random and Triplanar shaders. Added other usefull shaders like Patterns, Layer, Ramp, Curve Map, Remap, Wire, Side. The other shader nodes are also improved.
We will work on the render speed optimizations for the next release.
Download link (site registration required): http://centileo.com/forum/forum18/156-download-link-centileo-for-cinema-4d-v0570-alpha
Change Log: cntlc4d 0.571 alpha (2018 December 20)
[cntlc4d] Fixed focus distance bug on camera object when CentiLeo camera tag is assigned.
Change Log: cntlc4d 0.570 alpha (2018 December 19)
[core] New UVW Projection node supporting up to 4 UVW tags (mesh uv), spherical, cylindrical, cubic, flat, flat side, spatial and XYZ texture mapping coordinates. Texture coordinate system can be further manipulated (offset, scale, rotation) in the same way as Coordinates Tab of Texture Tag or UVW Projection node of Cinema R20. Offset, scale and rotation can be textured. Procedural texture coordinates are currently determined in the Texture Tag space (related to the object where it is assigned).
[core] New UVW Transform node which performs further manipulations on projected texture coordinates in the same way as the similar node of Cinema R20. Supported manipulations are offset, scale, rotation, pivot, rand offset, repetitions - these parameters can be textured.
[core] New Ramp node which can produce different colors based on the grayscale Input Map values and configuration of the Gradient knots. Up to 30 Gradient Knot values can be textured to produce flexible customization for the output.
[cntlc4d] Improved GUI for materials and shaders. E.g. the edit button doesn’t jump down when the shader is unrolled.
[cntlc4d] The Coordinates Tab and projection types of Texture Tag are supported (except of camera based projections).
[cntlc4d] CentiLeo Bitmaps and Environment maps are now collected correctly when the project is saved with the assets.
[cntlc4d] Fixed cloner object parsing issues which produced wrong scenes for CentiLeo.
[cntlc4d] Scene parsing now accounts for Cinema layer visibility changes.
[cntlc4d] Bitmap reset cache button is back.
Edited: Kirgman - 25.12.2018 07:14:05 (0.571 update with focus distance bugfix on camera object)
CentiLeo 0.570 for Cinema: http://centileo.com/forum/forum19/157
CentiLeo 0.571: Fixed focus distance bug on camera object when CentiLeo camera tag is assigned.
it seems something wrong in Displacement .
Hi Aimar, I probably guess what's the problem. Please, can you send me a bitmap for some tests? To info@centileo.com or here
and also try to multiply the bitmap in photoshop by value 0.9 or 0.95. It will lower all peaks and they will not be clamped here. Is it jpg or other 8 bit image?
you may increase the values later in a bitmap shader or by displacement height scale.
it Is TIF 16 bit.
after some playing with bitmap i fixed it .
and why corona haven't this problem
Edited: Aimar NL_21 - 21.12.2018 13:31:30
Don't worry, I will fix the issue. It happend because I tried to fix some aritifacts with dispalement for 8-bit images where almost white values created displacemnt aliasing. That fix shoudn't be enabled for 16-bit images. Simple :)
