Hi Congrats to this awesome renderer. Super nice to be able to scroll the timeline and see it update so fast. compared to other gpurenderers I use, this is fastest!.
There is som bug in the physical camera dof. it dont get updated and sets on frame 0 and keep the same distance the whole animation through even if animated. max 2019.
I also had some trouble with an animation that saved every second frame as black or alpha. may be I did something wrong when installed it thoug so, I check when I get to the office tomorrow. Here, at home, it saves all OK.
the Directional light dont work either but I think I red something about that...
Some things I miss most is Sun/Sky system of some sort and alpha through refraction/transmission
Best
Daniel
some dof/camera bug
Hi Daniel, thanks!
1) Physical camera dof. Have you tested the most recent 0.593 version? I have made a test and both Target Distance of Custom Focus Distance are animated and CentiLeo accounts them correctly from 0 to 20 frame in attached file. 2) Lost half of animation frames. There was a problem but it was fixed in 0.593 Is this problem still there? I have just recorder it for the same file and all is fine. As for other issues - they will be fixed, I know they are very much needed. But currently is too busy with complex out-of-core instancing
Hi, I tryed your scene in max 21 and I can´t get it to work. I tryed both target distance and custom focal distance. reinstalled the plugin and, still same thing.
It works perfectly ok when I render it in ipr but not in final render //Daniel |
for the record, I use two rtx cards 2080ti and 2060
The missing frames problem is gone after i reinstalled though
One thing I noticed is, it tackes the focus distance from the latest ipr render. so if I do a ipr render of the scene at frame 20 and then press final render. it will take the focal distance from frame 20, trough the whole animation
//Daniel |
You are right! I have tested from IPR, not from final
Will fix shortly
Daniel, it's fixed! The fix is uploaded. My appologises for bug. It was so stupid Also there are fixes for TyFlow scenes which had crashes.
