RSS
CentiLeo for 3ds Max 0.471 available (quality & materials improvement)
Merry Christmas to those celebrating it today!
CentiLeo 0.47 alpha for 3ds Max 2014-2017 is available.
It has a lot of quality improvements. Post-processing contrast adds nice image feeling. While most work was spent for material behavior improvement and bugfixing. Really many things were polished in cntl std material.
Download here: http://centileo.com/forum/forum13/104-download-link-centileo-for-3ds-max-v047-alpha
Light lister script by Ali Kavyani: http://centileo.com/forum/forum22/99-3dsmax-lightlister-script
Change Log: cntlmax 0.471 alpha (2016 Dec 31)
[core] Improved render speed for scenes with many lights and rough reflections
[core] Improved render speed for bump mapping on polished surfaces (with roughness close to zero)
[core] Fixed fireflies in few situtations
[cntlmax] Fixed crash when click “View Image” in cntlTexture and go up.
Change Log: cntlmax 0.470 alpha (2016 Dec 25)
[core] Added post-processing contrast setting. 0.5 by default, it makes the image more realistic
[core] cntlStdMaterial: glossyness usage as alternative to roughness (if checked then roughness is replaced with glossyness and treated accordingly).
[core] cntlStdMaterial: weight*color mixing mode similar to other engines
[core] cntlFalloff: parallel falloff mode
[core] Faster many-bounce internal reflections inside complex glass object.
[core] Roughness remapping. Now all the range 0..1 is more interesting unlike before when most interesting values were close to zero.
[core] Many bugfixes for material behavior when roughness is changed. Now the highlights are changing smoothly for small change of roughness.
[core] Fixes environment map brightness when seen through reflection
[cntlmax] Post-process can be performed when render is paused
Enjoy rendering with CentiLeo and share your opinion!
thx for your work, merry Christmas. :)
Thanks and here is reply:
Released 0.471 with few fixes primarilly related to noise reduction.
Happy New Year! :)
Hi Kirill,
Thank's for the updates.
hope you add oren nayer diff model in CentiLeo material.
Is there any chance for this?
Edited: Ali Kavyani - 14.01.2017 08:41:31
Hi Ali!
It's already added. Here is the difference between 0.47 (top) and internal 0.48 version (bottom). Everything is diffuse. 0.48 has Oren Nayar diffuse with roughness=0.4
Love the looks of 0.48
Absolutly fantastic.
Thank's Kirill.
