Nice updates.
Subscribe to updates:
[cntlmax] Added 3ds max 2019 support. [cntlmax] Fixed crash bugs for animation rendering of objects with Greeble modifier. Will update CentiLeo for 3ds Max on 0.58 release with new shaders and render speed optimizations.
//Daniel |
As for RTX rays acceleration hardware feature - not supported. At the current state of RTX ray acceleration feature - it may be not compatible with some current and future CentiLeo features. Btw, I will update CentiLeo for Max at the next 0.58 release ![]()
Thanks for latest updates.well done
Not sure if its the 4k resolution or something else. Best Daniel |
Thanks, good to know!
//Daniel |
really longing for an update now
![]() //D |
Great job guys keep up the good work
