Forums » Users » remi bouffort
first render test
playing around with centileo... post prod with photoshop
****Remib website****
**codingandscripting.fr**
first render test
hi this is my lastest renders with some volumetric light attempt, emission and global settings on cntl materials...
the apartment scene took 7:58 mn at 32 iteration (i also post the final render without post effect)... the creature with red emission took 7:40mn and the bust only 3:30mn on gtx 980 ti...
Edited: remi bouffort - Dec 19, 2019 12:19
first render test
Kirgman, cntlRamp works fine, the leaves are tinted by a linear gradient within the ramp in a very efficient way...getting some automnal mood in no time... 8)
first render test
i forgot i have some new pictures, using dof setup, which is really easy to render... i have also used the material converter function and it work fine with standard mat, really can't wait to see the next centileo alpha version...
first render test
hi kirgman, thanks for the precious informations, i'm gonna work on it soon, i know that random and ramp could give better result... good too for the node editor gui, this kind of visualisation is really efficient and prevent from wasting time adjusting material settings... so volumetric is just an option but in most architectural scenes it is almost essential... i know there are other priorities for now... i also plan to import metashape element to render with centileo i don't know if you have ever heard about photogrammetry... well i'll keep focus on the previous render for the moment, have a nice day and thanks again for your advices...
first render test
new scene, new renders and a post prod ingame overview... 11mn render for the castle preview with 12 iterations, the general map took 15 iterations 12 mn aproximatively..., quite a good result don't you think so ? any plan for a volumetric effect ;) ? have a nice day...
first render test
...Futhermore centileo gives really fast and good quality, next time i'll give it a try with some archiviz scene and perhaps animation, looks like Centileo gonna take part of my workflow... for some architecture projects and some visualisation design... i'll keep you informed about it...
Edited: remi bouffort - Dec 11, 2019 16:22
first render test
hello kirgman it's a non player game character modeling start picture, which gonna give me an overview of the rendering capacities in realtime, i have plenty mesh just waiting to be integered in a unity prototype, for sure my material setting is not really accurate, i have to play around with reflection normal map etc... baking could be an interisting option ;) i'll get back to you as soon as i have a good setup.... still discovering centileo... with a high learning curve... have a nice day...
Edited: remi bouffort - Dec 11, 2019 16:15
first render test
hi i'm trying to render a game character bust with subsurface/fresnel mat, i post some renders of the character... each are 3mn render with 32 iterations and 900x1280px...
Edited: remi bouffort - Dec 11, 2019 15:57
first render test
Hi kirgman, thanks for your help the bitmap setting did work. assuming that my sculpt with 3dcoat is not very detailed.i post a double screen view of my desktop with the mix shader i've used... mix shader behavior in Centileo is close to an octane functionnality so i didn't have difficulties to achieve my material. i also used some particular post process in the render saturation and gamma output... everything's good ! i can't wait for the nodal system to be developped, have a nice day...
Edited: remi bouffort - Dec 6, 2019 16:32
first render test
hi i have a second render, exported from zbrush and 3dcoat... the 3dcoat
export setting based on 3dsmax maps base
color/metalness/roughness/ior.i have also added some displacement and
bump map but didn't found the normal map field in the standard mat
setting. finally i have make a mix texture to separate reflections
1&2 setting from the first mat.i still don't know how to set my normal map
render #14:28 mn 20 iterations count 1920x1280px
render#2
4:38 mn 20 iterations count 1920x1280px
see you on centileo forum...
Edited: remi bouffort - Dec 6, 2019 07:57
hi kirgman, i'm gonna share a link to centileo on http://frenchcinema4d.fr/ which is the forum for the french users of c4d... there should be some cgartist interested in centileo in this community, have a nice day :)
first render test
Hi, i'm just trying centileo for some render...
i have a nvidia 980 ti and it took about 02:08 mn
to render this pictures with 20 iterations within c4d.
the background got some flakes shader.
the picture is 1500x1200px. :)
