Forums » Users » walterlee
plan to support Chaos Scatter?, plan to support Chaos Scatter?
Since the Forester plugin not updating for a long time,Chaos Scatter4 seems to be the most powerful scatter plugin on C4D2024. Does Centileo plan to support Chaos Scatter?
Round Corners
Any news about round edges feature?
random generator needs a "evolution" or "offset" option
Nervermind,I find a way.I use Shader Field to control the change.
The random generator needs a "evolution" or "offset" option.
here is what I want to create:
For example, I Voronoi Fractured a large box into several small blocks, I want to make some small blocks transparent and some opaque, and the transparency of these blocks is constantly changing, randomly changing from transparent to opaque and then to transparent, and so on.I hope this process of change is gradual, from transparent to semi transparent to completely opaque.
I hope you can understand my description.
Test with centileo and forest in C4D, Test with centileo and forest in C4D
According to my test, when using the forester plug-in, individual tree can be rendered correctly. When the trees are cloned onto the ground, the material will turn black.
this is a test scene https://drive.google.com/file/d/1vElLRB33m1nRhgxQZmsoUteBxUV0rYP5/view?usp=sharing
this is forester website:https://www.3dquakers.com/forester-for-cinema-4d/
A small test uses centileo renderer and the forest plug-in. It seems that there is a small problem with centrileo's support for the forest plug-in. Cloned trees need to be transformed into editable objects in order to correctly render the material of trees.
Realflow Mesher Object
Great! Thank you for your hard work. Have you considered supporting openvdb this year maybe? :)
In the 602 version,IPR shows RealFlow mesher object normally, RealFlow mesher object cannot be displayed in IPR version 614
