strange shadows
Hello friends, I would like you to help me, in this matter that I am doing wrong so that when rendering I get this malformation in the shadows, it is a simple scene illuminated with an hdr in hdr format and in 4k what am I doing wrong
Anyone encounter rendered frame getting infinitely stuck halfway?
I tried to make another render with less samples 4 and it got stuck without giving time to clean disk cache
as soon as iva rendering iva in increasing the ram memory filling the activity of the ram memory my ram memory is 16gb. yes, only that in the task manager of cinema 4d it kept processing PV cache and I don't know what that is, try to stop and crack cinema 4d and it closed
I have managed to render the scene in cinema 4d, I just had to be aware of deleting the disk cache, the global cache, everything in the image viewer and I realized that in the cinema 4d task manager a counter appears that does not stop even when the rendering is already finished, the task is called pv cache cleanup I'm sorry I had the automatic language translator on
here
He logrado renderizar la escena en cinema 4d, solo tenia que estar pendiente de borrar el disk cache, el global cache, todo en el visor de imagenes y me di cuenta que en el administrador de tareas de cinema 4d me aparece un contador que no para incluso cuando el renderizado ya ha terminado, la tarea se llama limpieza de caché de PV
[img]file:///C:/Users/MICRO/Documents/Lightshot[/img]
hola amigos tengo el mismo problema resulta que tengo una escena simple con material displasment normal map un cilindro y un terreno con pelo y todo se ve bien en el ipr de scintillation pro cuando voy a renderizar solo renderiza unos cuantos fotogramas y la escena no termina de renderizar en negro o simplemente no renderiza cinema 4d y se congela el visor de imagenes de cine ya he probado muchas cosas pero no entiendo esta version es centelleo 0.650
