it looks like, when I render an animation, that few frames are becoming black dots here and there. I dont know, what cause this.
I will send you two files, and if you look carefully, you will notice the dots, like in an old movie.
Any idea?
Black dots in animation
vblackrender., hi! I know this problem. It appears randomly and in different places. Basically some geometry small part is removed here and there. There is a problem to find solution because the bug changes positions and not always reproduced in the same conditions.
I hope that the problem will dissapear when the geometry engine (compilation + ray intersection) will be improved. Maybe some of geo compression scheme is the reason. But we need time to fix that.
I remember it appeared even few years ago
In my constant tests I randomly see the problem probably once per 2 weeks in different situations. After re-run it dissapears
Exactly! Very randomly.
At the moment it is not a huge problem. I can delete the frame where is a dot, or edit it in photoshop quickly. I hope your Idea will work.
Yeah, im sure this can make you crazy.
Archviz Potfolio:
