Available CentiLeo 0.53 for 3ds Max 2014-2018!
We have updated CentiLeo material system completely. The GUI and settings remain the same but the models of reflections, refractions, SSS, absorptions have all been updated to improve the quality and paramter response.
E.g. SSS have become correct and 10x faster (not a big deal because it was very slow before). But now it looks like diffuse if subsurdace scatter radius = 0 and shows logical behavior when increase the radiuses and combine the channels.
We have also intelligently killed the fireflies that could be seen through several glossy-glossy surface reflections using much smarter new GI Clamp algorithm.
Download link:
Change Log: cntlmax 0.530 alpha (2017 November 20)
[core] Subsurface Scattering is correct now and has 10x faster noise reduction due to improved maths. The speed of SSS is close to diffuse. Same as before it is based on 3 layers.
[core] GGX anisotropic reflections and refractions. Better looking highlights and fast. Some old scenes with rough reflections may seem to render slower 5-10%, but this is due to different look and changed highlights, the speed isn’t really degraded.
[core] Faster (less noisy) rough glass and shadows under rough glass due to better maths.
[core] Fixed Absorption parameters. They now affect transmissive and translucent objects and also their shadows.
[core] Improved quality of GI Clamp params. They now preserve glossy highlights better and kill the hotspots a lot smarter while keeping the highlights. Default GI Clamp values of 10 are very good if final post production image exposure is 0.
[core] Added “Expected Exposure” parameter that should be similar to the post production planned exposure. This is useful in cases when the lighting is very low in the scene and then user compensates it increasing the post exposure. In this case to make GI Clamp params and noise detector more efficient just set Expected Exposure similar to Post Exposure (+-1). Efficiently tuned GI Clamp and Noise detector may accelerate image rendering.
We are currently using JUCE library (
GPU Drivers
Pls, make the tests and send us feedback!
