Forums » Users » a1cat cato
CentiLeo for 3ds Max 0.586 available - speedup 2x to up to 10x, added many new shaders and emission
Hi there, another test with SSS ;).
It was difficult to fiddle down a little by little to find good values, but i heard that there will be a new help file with examples, which would be so helpful, so i will be waiting for the next update.
I will keep you up to date guys with the bugs, sorry to be late but i have some hardware problems right now.
Best regards
Edited: a1cat cato - Dec 2, 2019 03:37
Another test with the Physical Camera.
As a note for the new users , if you want to use IPR don't pause the IPR then close it . Close it directly without pausing .
- If you open the IPR, let it render , pause it , then close it and try to render a normal render : the render will be black , and if you try to run IPR again max will crash.
the correct way is :
- open IPR , use it as much as you want, and pause/resume it as much as you want. When you are done with it, and want a Full Render, then let it run first then close it from the X button. After that you can render a full normal render .
Of course this is just a workaround until it is fixed ;) :D. Shout out to the dev team :idea:.
Best regards
Edited: a1cat cato - Nov 30, 2019 18:26
Hi there , sorry to be late i am having some hardware problems :cry:. But i did a test i would like to share with you but i think there is no option to upload here . I don't know how to link images so they appear directly in the post so i uploaded it on imgur.
The drag and drop image worked Thanks :D
Ps: I had problems with the depth of field and took me so long to find the correct values , i wish there was some kind of feed back in the normal view port to choose DOF values quickly.
Unfortunately i can't open the IPR cause it crashes 3DMax, I will try the Physical camera option.
Thanks a lot for the hard work.
Best regards
Edited: a1cat cato - Nov 30, 2019 13:35
Hi there , hope you all fine guys :D , i thought i found another bug, but it was i simple mistake from my side ;) :oops:.
Thanks a lot guys , i will try to test it more and keep you up to date.
Best regards
Edited: a1cat cato - Nov 24, 2019 20:12
Yaaaaaaaaaasssssss finally :D .. thanks alot Kirgman testing it right now ..
I noticed i small problem and i hope it is also small to fix. When you open a scene and try the IPR, after that you hit pause in the IPR , closes the IPR window, and render directly after that , the render is black as it renders nothing. and if you try to start the IPR one more time Max crashes .
3dmax 2019 x64, win10, 2X 980tis
I hope it is just a small easy bug to fix.
Best regards
Edited: a1cat cato - Nov 20, 2019 11:45
Great :D Thanks alot Kirgman :D , can't wait for the max version to test it though :cry: :cry:, but i know bug fixing is difficult :cry:.
a maya version, and with more AOV and material converter , really can't wait to test them ;)
A real big thanks to you , i wish you all the best, and that i can be of a help here in the future.
Best regards.
Edited: a1cat cato - Nov 11, 2019 18:17
Awesome :D .. the pictures look very promising ..unfortunately i am not very familiar with Cinema4D :cry: .. gonna have to wait for the 3dmax version ;)
Edited: a1cat cato - Sep 27, 2019 10:59
Awesome
Hi guys , any updates ;) ..
Edited: a1cat cato - Aug 23, 2019 17:41
a1cat cato wrote:
Secondly, are those features are only for cinem4D, does the 3dmax version have different features ?
What i did understand is that there are 2 version, one for 3dmaxc and the other for cinema4D, every one has different features than the other. am i correct ?
The next release 0.58 will be both for 3ds Max and Cinema, the features will be syncrhonized 1:1. Only node-based GUI for Cinema will be done by 0.59. 3ds Max produce node GUI automatically for all kinds of 3rd party mate rials. But Cinema developers decided to hide this possibility and make node GUI only for own native mate rials, so we have to re-implement this basic bicycle.
:) :D :) :D :) :D :) :D :)
Awesome, thanks alot guys. I will be waiting for this version to test the new features
First of all i would like to thank you guys for the development , keep up the great work :)
i hope that i see also a node based GUI for 3dmax, i hope that i see all the features that are in the cinema4D version also in 3dmax too :(
Great job guys keep up the good work ;)
