Forums » Users » text-tree
How to render volume clouds?
How to render volume clouds,thanks
Can i rotate hdr pictures?, Blender can use nodes to control the environment, CentiLeo for Cinema 4D Support it?Thanks
get it,Thanks
Is it the circled label? Which option is used to control the rotation, I did not find it.
I know the purple circled control button is fine, but this is to rotate the camera perspective.
How to render the front view, The standard renderer can directly set the window view to render the front view,How can this achieve the same effect?
Thanks for your hard work
At present, I can rotate the view to get the light change, but if I lock the camera perspective, can we still rotate or zoom to change the hdr?
Thanks
Can node material be shared with other renderers?, Can node material be shared with other renderers?
thanks,
Very much looking forward to
标准渲染器可以直接设置窗口视图渲染前视图,CentiLeo for Cinema 4D如何 达到同样的效果?谢谢!
Edited: text-tree - Dec 23, 2021 02:16
I really like that this renderer is easy but not simple. One question is that it does not support the c4d standard material. so,Can the node material be used form other renderers like oc\redshift? I hope so.
Thank you very much for developing such a useful and beautiful renderer!!
