Had a render of looking from outside a building inside through a glass panel, very different results in IPR vs the final render in picture viewer.
Both rendered through the same camera so they should match... the IPR result would have been the desired lighting - there are a couple lights that are set to 0 for camera, reflection and transmission and they seem to not be effective in the final render whereas they show just fine in the IPR? How to get the same result for the final output?
Light in IPR vs Light in Final render, Weird difference in lighting results through a transmission material
Centileo Node Space? Help
Found out the material is ONLY editable in Node Space when creating it from C4D's top bar menu, not from the Material Manager window under Create Material > Extensions > Centileo. Node editor potentially crashes C4D when not in Node window setup
Hi. When i create a Centileo Material (mind you render settings are set to Centileo), it won't let me open it in the nodespace at all. Only materials that are in your example scene will open in it. Also yes there is "Nodes" in the upper right tab of C4D but then what?
