Forums » Users » sel
Python code to convert C4d materials to Centileo, How to replace the old materials by there centileo clones using python?
sel
User  Posts: 3
Feb 21, 2023 10:13
Hollo Kirgman, thanks for your reply
that's good news to hear ^^
sel
User  Posts: 3
Feb 21, 2023 08:53
I found a quick and dirty way to do that.. :)
by adding "return material0" to the CreatesCNTLmat function, and modifying main function like so..
Code
import c4d
# Get C4D material values
def MatConvertGet(material1):
    # Get the material's Name
    matname = material1.GetName()
    # Get the material's shaders
    shaderImg = material1[c4d.MATERIAL_COLOR_SHADER]
    shaderCol = material1[c4d.MATERIAL_COLOR_COLOR]
    shaderBumpImg = material1[c4d.MATERIAL_BUMP_SHADER]
    Bump_stat = material1[c4d.MATERIAL_USE_BUMP]
    shaderBumpVal = material1[c4d.MATERIAL_BUMP_STRENGTH]
    Col_texture_path = ""
    #Get color shader's texture path or color
    if shaderImg:
        Col_texture_path = shaderImg[c4d.BITMAPSHADER_FILENAME]
    Bump_texture_path = ""
    #Get bump shader's texture path or color
    if shaderBumpImg:
        Bump_texture_path = shaderBumpImg[c4d.BITMAPSHADER_FILENAME]
    return {"matname" : matname,
            "shaderCol" : shaderCol,
            "Col_texture_path" : Col_texture_path,
            "Bump_stat" : Bump_stat,
            "shaderBumpVal" : shaderBumpVal,
            "Bump_texture_path" : Bump_texture_path,}
# Create the centileo Clone
def CreatesCNTLmat(matname, shaderCol, Col_texture_path, Bump_stat, shaderBumpVal, Bump_texture_path):
    c4d.CallCommand(58000, 1036659) # creat new CNTL material
    material0 = doc.GetActiveMaterial() # Get the setected new material
    material0.SetName("SNTL_"+matname)
    # Color And Texture
    material0[c4d.IDD_DIFFUSE_COLOR] = shaderCol
    material0[c4d.IDD_REFL1_ROUGH] = 0.6
    if  Col_texture_path:
        Shader1 = c4d.BaseShader(1036812)
        Shader1[c4d.CNTL_XBITMAP_NAME] = "CColor"
        Shader1[c4d.CNTL_XBITMAP_FILENAME] = Col_texture_path
        material0.InsertShader(Shader1)
        material0[c4d.IDD_DIFFUSE_COLOR_X] = Shader1
    # bump map
    material0[c4d.IDD_TOGGLE_BUMP] = Bump_stat
    if Bump_stat:
        material0[c4d.IDD_BUMP] = shaderBumpVal
    if Bump_stat and Bump_texture_path:
        Shader2 = c4d.BaseShader(1036812)
        Shader2[c4d.CNTL_XBITMAP_NAME] = "BBump"
        Shader2[c4d.CNTL_XBITMAP_FILENAME] = Bump_texture_path
        material0.InsertShader(Shader2)
        material0[c4d.IDD_BUMP_X] = Shader2
    return material0
# Main function
def main():
    # Get the active material
    material1 = doc.GetActiveMaterials()
    for mat in material1:
        C4D_mat = MatConvertGet(mat)
        doc.SetActiveMaterial(mat)
        c4d.CallCommand(16370) # Select Material Tags/Objects
        tg = doc.GetActiveTags() # Get the active tags
        # Creat the new Centileo material
        newmat = CreatesCNTLmat(C4D_mat["matname"], C4D_mat["shaderCol"], C4D_mat["Col_texture_path"], C4D_mat["Bump_stat"], C4D_mat["shaderBumpVal"], C4D_mat["Bump_texture_path"])
        #loop through all the material tags of the old material and replace it with the new material
        for tag in tg:
            tag[c4d.TEXTURETAG_MATERIAL] = newmat
        # Delete the old material
        c4d.CallCommand(300001024)
    # Update the document
    c4d.EventAdd()
if __name__=='__main__':
    main()
Edited: sel - Feb 21, 2023 08:57
sel
User  Posts: 3
Feb 21, 2023 05:47
Hello,
I made a quick code to convert C4d Materials to centileo for a projects I'm working on..
the code just handels color and bump shaders that what I need for my project.. and its not complete working code beacose it's not handling expectations and errors ..etc.
Code
import c4d
# Get  material's Vals
    #Get the shader's texture path or color
    if shaderImg:
    if shaderBumpImg:
    # Color And Texture
    # bump map
    if Bump_stat:
# Main function
def main():
    c4d.EventAdd()
    main()
the code just create a centileo clone but not replace the original materials,
so my question is how to replace the old materials by there centileo clones after creating them automatically using python of course
PS: I'm not a programmer by any means, I just know a little of python with some help from chatGPT :)
Edited: sel - Feb 21, 2023 06:45
