A small test uses centileo renderer and the forest plug-in. It seems that there is a small problem with centrileo's support for the forest plug-in. Cloned trees need to be transformed into editable objects in order to correctly render the material of trees.
Test with centileo and forest in C4D
Thanks for noting a problem. Please, can you give me a link to this forest plugin and some small scene example? I will investigate this.
Btw, you may add variation using Random node or Gradient Ramp + Random nodes to add variation of green for the trees.
According to my test, when using the forester plug-in, individual tree can be rendered correctly. When the trees are cloned onto the ground, the material will turn black.
this is a test scene this is forester website: |
Oh, the Forester! Ok. Thanks for the links, I will look there, fix and then get back to you.
Btw, the issue you reported was fixed in the latest 0.64 release
