RSS
CentiLeo for Cinema 4D 0.560 available - mesh lights, adaptive multi-lights and R20
We now reelease an update CentiLeo 0.56 for Cinema 4D R16-R20. This time it improves the light sources, complex geometry shapes for light sources are allowed and many light sources are working much faster now and bugs are also fixes. On next release we will add more shader nodes.
Download link (site registration required): http://centileo.com/forum/forum18/152-download-link-centileo-for-cinema-4d-v0560-alpha
Change Log: cntlc4d 0.560 alpha (2018 September 6)
[core] Mesh Lights support. This is implemented with an additional Emission property of CentiLeo material. Supports arbitrary (even out-of-core) geometry shapes for the light sources.
[core] Adaptive Multi Lights 10 times faster rendering for glossy reflection surfaces. Also bugfixed many issues in this area.
[core] Bump mapping code totally changed (it also changes the look and scale of bump on older scenes). It has higher quality now and better combination with Normal Maps. Normal Maps now have all these flip R/G/B options.
[core] Fixed some problems with liquids inside glass in some modes.
[core] Extended CentiLeo Noise shaders with more noise types like Voronoi, Ronk, Ridged Multi-Fractal, etc.
[core] Faster bitmap cache generator (2x faster).
[core] Added real distance units for CentiLeo materials and light sources where it makes sense (e.g. displacement height, SSS scale, dirt shader max distance and etc.).
[core] Light sources may change the brightness on the surfaces for old scenes due to the distance units integration and some other calibration. Need to adapt for it.
[cntlc4d] Added support for Cinema 4D R20.
