Post-render settings only apply to IPR image but not final render?
How do you access the post-render settings so they save in the final rendered image?
It only affects my IPR images.
Administrator  Posts: 902
Jun 13, 2022 09:22
Hi, they should affect the final image. Do you have any post render settings override on the camera or no? I will check this on my tests
I just had default camera settings.
Post-render enabled was checked.
I just realized that I was using a motion tracked 3D camera solve, and I did not have a centileo camera tag applied. However, when I switch to a centileo camera I also have no post-render settings being applied to the rendered image. And even using a centileo camera tag and overriding the post-render I still cannot get the render to use those settings.
Also, I'm using multipass with diffuse and reflection passes.
EDIT:
I unchecked "Send RAW AOVs to Picture Viewer" and now it works.
So if I want to use post-render settings I need to have that unchecked?
Edited: ssjenforcer - Jun 13, 2022 23:11
Jun 14, 2022 05:10
Oh, I have forgotten about this option, of course this is the reason. It just kills the post and sends RAW image to PV with the intention to make post in the other image processing application.
