Forums » Users » Rodrigo Bitencourt Rodrigues
Pages: 1 2 Next
CentiLeo for Cinema 4D 0.541 available (nested glass objects and liquids, dirt shader, fixed bump mapping)
Centileo ID tag not working in R19
Noise Shader typo =
Turbulince
correct: Turbulence
Hi Guys!
please add a "About" icon at our Centileo menu that prints the version and other important infos like links for forum, list of fixes... etc...
I understand Kirg. thank you
Can I suggest something about the material preview scene?
please use a squared Area Light, this make the material preview a lot more sexy and I can see the Roughness value with more precision
can you send me the default material scene? just for some tests?
Edited: Rodrigo Bitencourt Rodrigues - 04.08.2017 13:40:33
Bug: Centileo should avaluate the play and stop(please add a stop button) of the IPR, not the window.
because sometimes I need render in Picture Viewer but I want to maintain the IPR opened(not rendering, just opened).
Edited: Rodrigo Bitencourt Rodrigues - 03.08.2017 11:34:38
Feature request: IPR Post Settings need a reset button.
bug report: C4D sculpting tag is not working with Centileo.
PS: sometimes update, sometimes not.
Edited: Rodrigo Bitencourt Rodrigues - 03.08.2017 09:07:12
Question: Are in the roadmap a separated config for preview and final rendering?
I think its very important IMHO.
I mean, not only rendering configs but hardware configs too.
Edited: Rodrigo Bitencourt Rodrigues - 21.07.2017 23:50:09
+ Material default projection should be Cubic or UVW, currently Spherical seems a bit unconvenient.
+ DOF Sensor Width should respect Camera F-Stop value, like a real camera.
lower F-stop = more DOF.
high F_Stop = less DOF
+ Area Light scale should respect the size of the Area light DETAILS TAB(Size X and Size Y) that way I can edit the size via viewport with Area Light helpers..
+ please unclamp materials Weight sliders.
currently its clamped in 1 so I can't push some values beyond
+ in the IPR we need a camera chooser menu.
currently it only work with the active camera...this can be a problem for product rendering workflow.
Edited: Rodrigo Bitencourt Rodrigues - 19.07.2017 18:54:03
Nice! hey! please add a Centileo Material menu at Material Manager menu like the image
https://ibb.co/mmeH5Q
this will be good by default.
currently we have the menu at the top centileo menu but we have this in Material manager too.
CentiLeo for Cinema 4D 0.483 available (multi-GPU and efficiency improvement)
I know buddy, I'm just reporting what I see. i think its the reason for that Forum.
its possible implement a better feedback for sliders like color sliders?, now the ipr only update when you release the mouse button... will be nice if ipr update it in realtime like Octane and other render engines.
Edited: Rodrigo Bitencourt Rodrigues - 11.05.2017 14:34:55
Hi Kirg! no freezes in 0.483 nicely done!, but material tag order still wrong.
I did a video showing how c4d behaves about it
video: https://mega.nz/#!mphFwbLL!zFWMgrQDghqYYn-zn9_5DLi-ib0gzhILkc9S-_XrKxs
image: https://mega.nz/#!DoJBHIYQ!fjDrzQLvCAro7K6cZ1IM491HhmJuyLoQz22VclsFUrI
always from left to right.
the most at right material tag will be always the top material on the render over the other tags.
Feedback: 0.482 still freezing in the same case of materials.
nvidia driver 382.05
nvidia gtx 970
nvidia gtx 970
try change the order of materials tags....it happens too.
Edited: Rodrigo Bitencourt Rodrigues - 05.05.2017 04:00:54
I do not know if it is the best behavior, other renderers have a global option in Cinema 4D preferences and an option to override globals in the scene options. I think this is the best way to implement it.
Imagine that whenever I create a new scene I will need to adjust which GPUs I will use.
This is not good from the point of view of practicality.
Feature Request: add an option on Cinema 4D preferences to set the defaults GPUs for rendering(like this example from redshift)
image: https://ibb.co/de9QGQ
Hi Kirg! thanks for the sss in one tab. much better now!
here the link to the bug video: https://mega.nz/#!S0pnxD5Y!LG3XYfe6Wgyq8d4I_20qpubFoBQ0lca1NooFip7wRQc
dual nvidia 970 GTX
Request feature: a channel for material alpha(Std Material) it will allow us to use a material stack like we have in Cinema 4D
plus: the material tags need to be avaluated from left to righ at object manager
see the image: https://ibb.co/n6xFi5
Edited: Rodrigo Bitencourt Rodrigues - 03.05.2017 16:50:54
Hi Kirg! I will do a step by step video soon
Hi Kirgman! great news buddy!
I'm testing here, thank you!
bug report: IPR and cinema freeze when you change from a material to another when IPR is running.
CentiLeo for Cinema 4D 0.471 available (quality & materials improvement)
Hi Kirg! how are you buddy? any news to us?
"Very big thanks for your feedback! Not easy to do everything early. But step by step we will work on this."
I know my friend! no worry about it! keep your hard work!
Yes,translucency in a separate tab and with weight will make our material much more flexible.
SSS in one tab is more handy because you can adjust 3 layers in a easy and fast way.
"We need a compositing tag, a object buffer system and a material id output."
We plan to do it in a couple of versions. There are many possible ways to do it. Need to figure out the most convenient one and do it. What good example reference would you recommend?
I love the Corona Renderer AOV management, is a state of art, its very handy! take a look!
and the C4D Compositing tag are a charm!
About alpha channel: is the same Geo Mask tab but in the std material. It is possible? Will be more handy that way.
Hope to see comments from other guys on the subject too, especially on the number of required selectable UV tags in material textures.
I rarelly use the maximum of 3 or 4 uv per object.
Cinema material tag assume the immediate uv tag at right side of the material tag.
maybe you can do a slot in the material to receive the uvw tag... its an idea.
PLUS: We need a emitter channel tab too
Edited: Rodrigo Bitencourt Rodrigues - 22.01.2017 17:52:56
hi guys! sorry my delay!
Feedback:
Translucency can be a channel instead inside Diffuse?
Std material can be only with diffuse and an reflection coat on by default.
SSS channels can be grouped(splitted is not handy)
Translucency mix slider is not working
IPR status info can be off by default.
We need a bump intensity slider to positive and negative values(like cinema 4d standard material.
Our displacement need a scale input.
Our material can respect the material tag uv inputs? its very important.
c4d allow to use multiples uv tag per object
how Centileo manage that?
The displacement channel can be in the std material too?
We need a alpha channel to our material.(not like the multi material, we need one to hide some parts of the model.)
Edited: Rodrigo Bitencourt Rodrigues - 21.01.2017 10:02:10
Hi guys! How I can set the value of displacement? I have a bitmap input but I dont have a unit of scale(like c4d displacement), It can be done per material or only globally? sorry my poor english.
CentiLeo for Cinema 4D 0.453 available (faster, many lights, light pass blender)
Feedback: Centileo Camera on the menu: When you click it should create the camera assuming the position and rotation based on the editors camera, just like the c4d camera button works.
question: Centileo is ready for animation?
Edited: Rodrigo Bitencourt Rodrigues - 02.12.2016 04:44:40
No more crashes! uhul! I will test a bit more tonight!
Feedback: I think the ipr size should be the same as the final output with a percentage control.
You can have 1920x1280 at the final render and preview it at 100% or 30% (640x426) of the size at ipr
the ipr size on centileo render tab is not handy.
Hi Kirgman! Another thing can be help making Centileo more confortable: [img]file:///C:/Users/cyano/Desktop[/img]
http://imgur.com/a/iDLMM
nice!!! im very happy with this render engine! keep the good work!
please make a web gallery to show some Centileo renderings, will be nice too
Edited: Rodrigo Birtencourt Rodrigues - 03.11.2016 06:41:05
Pages: 1 2 Next
