some dof/camera bug
some dof/camera bug
One thing I noticed is, it tackes the focus distance from the latest ipr render. so if I do a ipr render of the scene at frame 20 and then press final render. it will take the focal distance from frame 20, trough the whole animation
//Daniel |
some dof/camera bug
The missing frames problem is gone after i reinstalled though
some dof/camera bug
for the record, I use two rtx cards 2080ti and 2060
some dof/camera bug
Hi, I tryed your scene in max 21 and I can´t get it to work. I tryed both target distance and custom focal distance. reinstalled the plugin and, still same thing.
It works perfectly ok when I render it in ipr but not in final render //Daniel |
some dof/camera bug
Hi Congrats to this awesome renderer. Super nice to be able to scroll the timeline and see it update so fast. compared to other gpurenderers I use, this is fastest!.
There is som bug in the physical camera dof. it dont get updated and sets on frame 0 and keep the same distance the whole animation through even if animated. max 2019. I also had some trouble with an animation that saved every second frame as black or alpha. may be I did something wrong when installed it thoug so, I check when I get to the office tomorrow. Here, at home, it saves all OK. the Directional light dont work either but I think I red something about that... Some things I miss most is Sun/Sky system of some sort and alpha through refraction/transmission Best Daniel |
really longing for an update now
![]() //D |
Thanks, good to know!
//Daniel |
Not sure if its the 4k resolution or something else. Best Daniel |
//Daniel |
When will we see an upgrade?
//Daniel |
Yes right. Animated dof focus.
linked to camera target or even better a just a spinner you can bind to an expression //Daniel
OK Thank you. For some reason I didn´t get it to work earlier..
Will there be a way to control dof focus in the next release? //Daniel |
except the blend map dont work for bump for some reason?
OK Semes I have done something wrong then. Now bumpmap works with everything
even hair works now!! ![]() //Daniel |
Hi is there a way to use maps other than bitmaps as bumpmap? as it is now I cant even put a color correction node on it
//Daniel |
![]() //Daniel |
Strange artifact on Geometry, Some kind of bug
