Node Shader visibility in viewport
Textures in viewport
Is it possible to view textures in viewport when using node material. At the moment they are all default white
Administrator  Posts: 978
May 15, 2024 20:15
The viewport materials are not with textures by default just for Vram and computation optimization purpose.
But you can enable viewport textures with 2 methods:
1) Connect any texture of the node editor to the Output Viewport Color port. And it will work constantly on viewport until you mute it. But this connected node will be for Viewport, not for Interactive preview render.
2) You can switch Solo Mode on any node in node editor (including materials or unconnected nodes) and show the texture both on Viewport and Interactive Preview render.
