And this result i got with standart cinema render
Jan 4, 2021 10:39
Hi. I try this render and i realy like it. But normal mup not supportet at this moment? I tray load normal mup into the bump. And got result
And this result i got with standart cinema render ![]()
- Jan 4, 2021 10:41
Jan 4, 2021 13:12
Hi Alex, and welcome here!
Have you checked the flag "Is Normal Map" inside CentiLeo bitmap? This flag is at bottom of Bitmap. There are also other Normal Map flags to swap the channels. Connect it to Bump slot of CentiLeo material. Btw unlike Cinema you can mix Normal Maps and b/w Bump Maps in arbitrary way because internally they are all converted to b/w bump map for manipulations.
Jan 5, 2021 01:41
It's work! Thank you.
