CentiLeo often causes Cinema 4D to freeze
CentiLeo is one of the fastest renderers I have used so far, at least for moderate product rendering or other scenes. I am really pleased with the current version.
But Centileo freezes over every little thing. Cinema 4D freezes constantly. Either when you use the color chooser to select a color in the Centileo material or sometimes when I want to start rendering with the Picture-Viewer. The Picture-Viewer opens and freezed to a white window. It often happens when the IPR is open simultanously. I don't know.
It seems to be a Threading-Issue due to certain CallCommands() maybe?
You are constantly afraid that if you press a button CentiLeo will freeze Cinema 4D again. I use Cinema 4D R23
Edited: 3Deoskill - Dec 9, 2024 15:04
Administrator  Posts: 982
Dec 9, 2024 22:37
Hi 3Deoskill and welcome here! Please, can you drop a video screencast that shows evidently how it freezes the Cinema 4D? The minimal scene project file may help too. Also it would be interesting to know your PC specs.
Does it freeze forever or stops being frozen after some time?
As for IPR and PV they don't work simultaneously. The PV has more priority, so we pause the IPR, then PV makes it job and after that the IPR launch from scratch reloading the scene.
Threading... CentiLeo and it's plugin is very multi-threaded. But it was bugfixed a lot, and I don't know for myself any significant operational issues. I also have R23 version still available and can launch projects from there.
