2 Wishes
Hi, i want to say thanks for good free tool. But i have 2 wishes to it:
1 - Is that possible to make "Max iterations" ,below 0? For example i need superfast, draft prerenders of animation, and say 0.3 - 0.6 is fine for that
2 - Add parallel camera (for isometric)
All the best
Administrator  Posts: 982
Jul 15, 2021 06:02
3D220, welcome here! Thank you :)
1) No. It's used in artchitecture of renderer at this moment. For ready rendes Max Iters = 1 is the minimum. The issue is related to texture pre-population from disc caches. If you need faster pre-renders then why not using lower resolution? Also the iteration will become faster in few versions :)
2) Ok, will do.
Nice to hear, thats good news.
And I'm really amazed at this is designed by russian guys :)
Jul 15, 2021 13:38
Thank you! Are you russian too? :) Greater releases are coming soon btw 8)
Yes. From Vladivostok.
Looking forward for greater releases and good luck ;)
Jul 17, 2021 04:00
I am from Novorossiysk and Moscow. Thank you for wishes! :)
I think you need more promotion your product
Jul 20, 2021 05:30
Yes, there will be promotion of course after a couple of more versions
