Difference in behavior between centile 0.706 and 0.707
Hello again, Kirgman.
After updating from "Cencitleo 0.706" to "Centileo 0.707," an unwanted effect occurs, as shown in the images.
I'm attaching a sample scene that reproduces the problem.
The thing is, I'm adding "hair" to the head of a character that will later be cloned hundreds of times. To reduce the weight in the render and in the scene itself, I group the hair geometry or several hair models under a null that is hidden from the render and the viewport.
I create an instance of that hair model and set it as a "render instance." I then make it part of a cloner that positions itself on a single vertex of the character's geometry in "multi-instance" mode.
The problem is solved by setting cloning to "instance."
My problem is that I have several projects with hundreds of characters using this technique. And it's impossible to go character by character, modifying the parameter.
Besides, it leaves me wondering under what other circumstances the use of the cloner might affect me.
Best regards.
Administrator  Posts: 978
Sep 26, 2025 07:20
Hi Jiv! Thanks for the excellent bugrep!
It's fixed and uploaded, please redownload the update using the usual link.
