Hi everyone,
CentiLeo 0.50 for 3ds Max 2014-2017 is ready! It has a lot of important bugfixes for refractions, diffuse interreflections, etc. Some things like new IPR GUI took a really a lot of time due to fixing new bugs related to it. But this was solved. Hope to add more graphics features to CentiLeo asap.
Download here:
Change Log: cntlmax 0.500 alpha (2017 July 19)
[IPR] Changed GUI engine for IPR mode to JUCE library (. All IPR controls like image resolution and post settings go to the IPR window. It opens the IPR window faster, process images faster and is very cool. Later will add DOF, light pass settings and more cool things there too.
[core] Fixed wrong glass refraction patterns. It is also accelerated a bit for many multiple internal glass reflections.
[core] Improved the look of shadow from the glass objects.
[core] Improved rough glass render speed and look.
[core] Fixed loss of light energy for diffuse interreflections.
[core] Faster render for HDR lighting with very bright high-contrast spots (thanks to a bugfix).
[core] Fixed problem when display GPU participates in multi-GPU rendering. Before fixing this the display GPU could even deaccelerate collective rendering. Right now display GPU accelerates the multi-GPU render (however remember that display GPU also shares resources with native C4D viewport).
[core] Reduced peak RAM memory consumption when scene with huge meshes is loaded. Just valid and useful data takes place but temporary data doesn’t consume huge memory like before. E.g. for 50M poly meshes it is reduced by ~10GB.
[core] Out-of-core texture cache doesn’t consume all maximum capacity upfront. Now it saturates the cache on demand (when you add textures until the limit that you set in max OOC texture cache setting). It results in minimum RAM consumption (2GB) for blank scene (lower than before).
[cntlmax] Fixed window crashing error when you have opened Corona render IPR before CentiLeo.
[cntlmax] Fixed crash when change animation time and cntlLight (or cntlUber) was present in the scene.
[cntlmax] Fixed zoom scale of viewport light source representation. Light source names are off by default (may be switched on in LS settings).
[cntlmax] Fixed RAM memory consumption when IPR is open for several hours.
CentiLeo for 3ds Max 0.500 available (nice bug fixes)
Jul 20, 2017 11:49
Very nice. Sometimes Max stops responding after ipr or material window closing. Have to force-close app.
Jul 20, 2017 12:04
Pls, can you describe this case? What GPU (or several), what kind of scene and the actions you did before it stopped responding. I had some crash on my computer with 2GB GPU (750ti) which reported just 1GB remaining for renderer after OS and viewport consumed their GPU resources. This remaining 1GB is quite small for renderer (it can work but not as efficient as with 4GB+). How much memory available for GPU can be seen in Harware Settings of CentiLeo for each listed GPU. Do you close the whole 3ds Max or just IPR to make it alive again? This is the first version with new IPR engine and need to find all these bugs.
Jul 20, 2017 16:51
Hi. I was testing on my old laptop with 650M. Sometimes it hangs when closing ipr. Have to restart app. Will try next week on my workstation.
how do you enable refractions in alpha chanel? Is there a way to make an object invisible in alpha? sampling params are different now as in manual. What is the best approach to speed up rendering and to fight fireflies? thnx! |
Jul 20, 2017 16:52
Simple scene, couple of teapots.
Jul 20, 2017 17:27
Ok, I see. I will try to double-check and polish some things to make better stability for new IPR implementation. Strange because in Max plugin it doesn't do anything serious when close the window.
Also will add GPU priorities to Hardware settings in attempt to improve IPR fluence when there is just 1 GPU in a system. The manual is old enough. Need to upgrade it a lot. Will do it after some 0.55 version when will add more shaders there.
When the sampler reaches Min number of iterations and desired "Noise level" for pixel then it stops rendering it and contiunes processing only pixels which have more noise then specified in "Noise level". But if pixel sampling has reached Max iterations then it stops regardless of noise value for pixel. Redshift, Corona, Fstorm all have similar settings. Octane too (but they have slightly more settings). Our noise level internal estimation is conservative. At value 0.01 it doesn't give chance for noise where e.g. Redshift stops at 0.01. This is good for quite dark shadow areas. The other optimization settings are as usual: number of all ray bounces (and max number of diffuse only bounces which can be lower than overall num of bounces). Diffuse bounce is a ray bounce off surface with roughness higher than 0.1. We also have clamp values 1) for direct lighting, 2) specular direct lighting (everything reflected from perfect mirror or glass with roughness less than 0.1), 3) and clamp for indirect light. The last 2 may give fireflies in some cases. Try reduce them and see. What kind of scene you have fireflies?
Jul 21, 2017 03:47
Thanks! What about alpha visibility? Objects with refraction are solid in alpha. Am I missing something?
Jul 21, 2017 11:42
Aug 1, 2017 09:43
Hello, great work on debugging and optimizations !
I was wondering if it would be possible to rename the render pass "Reflection 1" and "Reflection 2", as they now are exported as "RenderName_.Beauty Reflection 10060.jpg" and "RenderName_.Beauty Reflection 20060.jpg" for example, and so are read as frame numer 10060 instead of 0060 in softwares like After Effect and such. Thanks ! Best regards, Thomas |
Aug 1, 2017 11:26
Aug 10, 2017 08:00
Hi, is there a max 2018 in the works?
//Daniel |
Aug 10, 2017 13:01
Hi Daniel, yes of course.
0.51 will come in around 2 days but with no 2018 Max. Hope to do it in 0.52 release
Aug 10, 2017 19:49
Aug 14, 2017 04:50
I have to use the spinners to to adjust the ipr size. If I try to type it in, it behaves strange as if the number pad don´t work
//Daniel |
Aug 14, 2017 05:44
Hi Daniel, I know the problem with keyboard input (it happens in plugin for Max, and not in plugin for Cinema).
Currently we are finishing 0.51 for Max. Almost done. Later probably with small update will fix that problem.
