IPR crash when activating "Importance Sampling" on emissive material. And it crashes Cinema 4D.
Hello again, Kirgman.
I've encountered a new problem. In this case, it refers to the "importance sampling" of an emissive material.
I've attached a video captured from my scene.
The thing is, with conventional lighting, it works without a problem, and I can orbit the camera without the IPR failing.
Afterwards, I turn off the conventional lights and increase the power of an emissive material.
On occasion, the IPR has stopped working, but I'm not going to use it in that mode without activating "importance sampling."
The problem arises when I activate "importance sampling." Usually, on the second or third camera orbit, the IPR crashes, and when I close it, Cinema 4D freezes.
Regards.
Vídeo
Administrator  Posts: 965
Aug 11, 2025 20:36
Hi Jiv, yes I see the issue. Thank you for bug report!
Sometimes it may be needed to reload the IPR scene with manual reload button when you toggle this Importance Sampling checkbox. At least it was needed in the past, but today probably not, however experiment may tell exactly :)
Btw is it Bulldozer kernel?
I notice this non finishing render with 95/96 status.
Please may you send me this scene too for another bugifx? At this moment I am actively bugfixing, and probably working on the same problem right now.
Hi Kirgman.
It's 7:00 am for me, and I've been up all night.
As soon as I'm back online, I'll compile the scene and send it. After spending all night testing the scene... It's not just about "importance sampling." It crashes both in the IPR and in the render sequence when using an emissive material, but randomly.
Correct. I was using Bulldozer
I hope to send you the scene soon.
Edited: jiv21 - Aug 12, 2025 01:11
I forgot to mention in the email that "motorblike" mode doesn't crash when you have real lighting in addition to the emissive materials.
The crash in the IPR and rendering primarily occurred in "Bulldozer" mode.
Aug 17, 2025 16:04
Thank you very much for note. I guess I know why it happened :)
