Forums » Users » Has
composition tag, exclusion
Has
User  Posts: 6
Apr 30, 2021 13:04
Thanks for your reply! Will wait foor updates!
Has
User  Posts: 6
Apr 26, 2021 02:33
I apologize, I did not put the question correctly. I mean, there are several objects in the scene + environment map (HDRI) The reflections on the floor should only be from these objects, while the reflections from the HDRI should affect the objects in the scene. If you understood me correctly and this is possible, I would be grateful if you throw a scene
Hidden Text
Has
User  Posts: 6
Apr 25, 2021 12:00
Are there any plans to add the "Exclude" function as it is implemented in physical render?
Example: Do not output reflections from hdri to the floor.
Hidden Text
Edited: Has - Apr 25, 2021 12:03
C4D Film Offset Issue
Has
User  Posts: 6
Apr 9, 2021 06:20
Amazing! Thanks!
Has
User  Posts: 6
Apr 4, 2021 23:35
Hi Has , and welcome here! Camera Offset? Ok, I need to fix
Thank you! It will be awesome!
Has
User  Posts: 6
Apr 2, 2021 03:44
Yes, big difference between c4d camera and ipr.
Please fix it!
Edited: Has - Apr 2, 2021 03:50
