Yes CentiLeo works well, all renders and materials configs on atributes tab works fine.
The only problem is only this crash when i try to add more nodes.
The CentiLeo2024 folder is on the correct path i believe!? you can check on this print, and also check the 3 json's on node foder
![](https://i.imgur.com/UvnUJlG.png)
this is the error that pop when i click on plus icon:
![](https://i.imgur.com/ZrYZRnD.png)
and this is the _BugReport.txt , i dont know if this helps, maybe:
About the build, i can try to update the version later but right now im with a lot of works in progress and im afraid of lose some plugins/configurations on update as it already happened with me on past.
If it's the only way to solve it I can wait but it would be nice if there was another alternative, thank you
