Forums » Users » Tiago Adloff
Hello guys, I made some test for comparison proposes between CentiLeo and Redshift last alpha version:
Each render time is on history by selection highlights.
I did similar render setup for CentiLeo and Redshift, and all Redshift settings are same only changing the Primary and Secondary engines.
The PC configuration:
Core i7 4790 - 8 Threads
32Gb RAM
1x GTX 970 4Gb
Hey Kirill, thank you for comparison with Redshift, I'm doing some tests with CentiLeo 0.50 here at home, but I'm feeling that new IPR gui is slowing down my C4D session, I have no sure about it, so I gonna test it with my workstation machine at work.
I'd like to suggest mesh light or material emission feature.
Hello Kirgman,
I see that when I'm using area light, and change the Size X and Y in details, the light intensity in IPR is decreased, but I think it is very diferent or weird, because in my all past experience with other renderes like mental ray, vray, arnold, thea render, any way, it always increase.
Other thing that I see is the default environment color illuminates the scene, only when I set black color it is off, or when I'm using some HDRI image. So there is some diferent way to disable this parameter?
Thank you one more time Kirgman, the infinite light work perfectly!
I tested using directional light with sun tag, but there is now directional light working.
Thank you Kirgman, this is amazing, I think I gonna change my c4d workflow to CentiLeo, it is so fast and speed up my workflow a lot.
Cheers.
There is some plans to implement emission or mesh light in next alpha version?
I really in love with CentiLeo, bellow some my studies:
http://i.imgur.com/FCuXaOE.jpg
http://i.imgur.com/e5RqVq1.jpg
Hope the physical sun and sky will be implemented soon.
