Array under Null objects
hello again
it seems Array and Instance( if i Instance the Array ) under three Null some object disappear and if i Continue and put on 4 null more object disappear .
but Array without Render Instance option work perfect .
Array B.jpg (310.9 Kb)
Array Af.jpg (234.81 Kb)
Administrator  Posts: 894
Nov 28, 2016 11:31
Hello Aimar, please, can you attach this small sample scene? So I can test as it is.
and you can put more Null objects .
i think the problem is render Instance in Array and Cloner .
Edited: Aimar NL_21 - Nov 28, 2016 12:13
Nov 29, 2016 12:41
Hello Aimar, thanks for the hint! Just working on this bug and testing the things.
Will likely publish CentiLeo 0.45 for Cinema today but without this fix (and also few others mentioned). Just need to output that many new things that we have done so far in the core. But in the later few days hope we fix this and other minor suggestions too.
Nov 30, 2016 20:42
Hi Aimar,
Not promissed, but fixed :) however with delay... Test it please.
Actually you have found some hard coded limitation inside our plugin code. We have simply stopped traversing the object graph after the level of 5. So there were missing elements. Now the limit is 15. Not so good that it is a limitation but it is high. Actually we want to get rid of such limitation and support nested scene graph inside CentiLeo in a similar way to Cinema. Right now internal graph of CentiLeo is flat list of instances similar to 3ds Max exported lists. But we hope to generalize it in some future.
