Ramps and the best channel to put them in
I have tried to add ramps to everything fr om just the color channel to just about everything else and i cannot get the effect i would expect a ramp to do. Wh ere is the best place to add a ramp?
Administrator  Posts: 985
Apr 26, 2019 12:32
Hi Chuck and welcome to CentiLeo forum!
Ramp node is needed to create colored output for black/white Input Texture. For example, you may attach some CentiLeo Noise shader to the "Input Texture" slot of Ramp and then create green, blue, red, yellow, etc knots in the Gradient field of Ramp. You may also add Random shader (uniformly distributed greyscale colors) to the Input Texture of Ramp and create colored knots of Gradient to determine how frequent is red, how frequent is blue, etc. in the variety of objects with attached Ramp + Random shader.
You may also add Fallof shader to the Input Texture of Ramp and make colored knots. This way there will be color variations depeding on the view angle.
Kirill
