Proxy Creation
User  Posts: 24
Nov 4, 2023 00:13
Im trying to create a proxy to scatter with TyFlow. The reason is that I have some problems with TyFlow working after changing render engines and I want to try to scatter proxies instead if possible.. My issue today is when right click on object to export as proxy, the object disappears from the viewport. It is also not replaced by a proxy mesh, and it does not export to a designated folder.
Administrator  Posts: 983
Nov 4, 2023 14:31
CentiLeo proxy is probably broken and needs some fix, but I think that Corona or Fstorm proxy does work as needed inside CentiLeo :D 8)
User  Posts: 24
Nov 4, 2023 17:59
That is great! :D I do see it scattering the proxies now but would you have an idea why I cant render TyFlow? I was trying the proxies to see if that was the issue. Particle interface option is active. Ive seen info in the forum that it has worked in the past but unfortunately whatever I try it wont. Unfortunately the TriMesh option is too heavy for vegetation scattering.
I also believe we have discussed in the recent past not rendering Forest Pack. Do you know of an option I can try to render any type of scatter that Centileo is compatible with? Thank you for your time.
Edited: DM50 - Nov 4, 2023 18:06
Nov 4, 2023 22:51
Forest Pack is supported btw from 0.67 so do the RailClone.
As for TyFlow then the TriMesh is the must have option as far as I remember but I need to see. Can you please send me a minimum setup from a problematic scene?
User  Posts: 24
Nov 4, 2023 23:59
I had thought so for Forest Pack but I keep getting the usual error. After closing/opening Max it now works :\ Ill also try to get a TyFlow scene over. TY.
Nov 5, 2023 07:27
Then I need a scene with ForestPack to try to investigate your error. A lot of things were fixed, but probably something was missing.
info@centileo.com my email or PM here
