Aniso issue.
Aniso effect works fine on material ball preview,but not work for production render and IPR.
maybe its my fault,I only put a HDRI map on background,so the anisotropic effect of the lighting cannot be clearly seen. By the way, can the reflection achieve an anisotropic effect under HDRI lighting?
Administrator  Posts: 966
Jul 10, 2025 07:33
Hi Blur! To see aniso effect you need to have a highlight. At first, please, make your roughness value higher, for example 0.5. Then set anisotropy to 1. And then you may rotate it and see how it works for you
oh thank you ,I will try again
