Aniso issue.
Aniso effect works fine on material ball preview,but not work for production render and IPR.
maybe its my fault,I only put a HDRI map on background,so the anisotropic effect of the lighting cannot be clearly seen. By the way, can the reflection achieve an anisotropic effect under HDRI lighting?
Administrator  Posts: 957
Jul 10, 2025 07:33
Hi Blur! To see aniso effect you need to have a highlight. At first, please, make your roughness value higher, for example 0.5. Then set anisotropy to 1. And then you may rotate it and see how it works for you
