Cool renderer
A brief trial of the renderer
Some problems found are that the mask channel and color will affect the black part of the mask. In theory, it should be just pure color and will not affect each other.[img]file:///C:/Users/Administrator/Desktop/mask2.jpg[/img]
Administrator  Posts: 982
Sep 13, 2024 22:27
Thank you and welcome here!
Your image hasn't attached correctly, please, can you drag and drop it clicking Upload files or moving your image to the area with "Upload files" in Reply form
Do you talk about Alpha in CentiLeo bitmap node or the Alpha in the render image?
The Alpha Image is accessed if you connect the Alpha channel output port of the CentiLeo Bitmap node.
Sorry, it's my first post, I uploaded the screenshot again
Sep 14, 2024 05:46
You see reflected color from the other object because you have checked On the flag "Reflections & Refractions" in Mask Aov settings.
In material settings you have tinted the color of the material that is hit.
All is correct here. Just switch off "Reflections & Refractions".
Great, this renderer is so powerful and has high controllability
Sep 18, 2024 08:39
Thank you! Working to do a lot more!
