Centileo 0.612 Seems very unstable
Crashes often when opening IPR
Just been using the new update and the texture tag issues seem fixed but it's become very unstable and has been crashing whenever I opened the IPR window. Put the old 0.602 version back on and its rock solid again. I've attached the Bug Report if it helps. Not sure what's broken, I was really surprised when it kept happening as it's been really stable - still these things do happen:)
Ron
Administrator  Posts: 982
Apr 8, 2021 17:28
Hi Ron! Oh no :) Please, can you give me a scene to info@centileo.com where it's unstable and what things are you typically doing to run into crashes?
Cinema bugrep files don't help in our case.
Apr 8, 2021 17:58
Ron, this is a quick note. Make sure to remove the old CentiLeoRXX plugin (all folders and DLLs). And only then copy the 0.612 to that place. Probably some DLL files were left unchanged and this makes crashes.
I am not seeing any crashes in my scenes yet also with stacked texture tags.
And if you send me a scene, please, write the Cinema 4D version in use, and GPU model too.
Apr 8, 2021 20:59
Hi Ron, I have assumed few things could be wrong potentially and have generated another package of plugins with potential fixes for stability.
Please, can you check them? This is the experimental CentiLeo plugin: link
Apr 9, 2021 20:58
Ron, thank you for scene to email!
With this I have fixed the bug and it's uploaded to "Download" section. It was a silly access to normals Phong tag where it didn't exist :)
