about material node editor
Hello, I would like to ask about the preview of my material node editor. Only one shader ball appears. Thanks.
CentiLeo version 0.698
Edited: Eric Chen - Nov 9, 2024 09:15
Administrator  Posts: 984
Nov 9, 2024 01:10
Hi Eric, but what do you want to do with this preview? What's the question?
I looked at your website and learned from it, and found that the content on your website is different.
Nov 9, 2024 01:57
Where is the difference? The language? :)
Preview; yours has 2 balls, mine only shows 1 ball
Nov 9, 2024 11:44
It can be different version of Cinema 4D. The image from your part is 2025, and the one in the Manual is 2023 or 24
Thank you very much
My Node editor does not show the presets. I click on the + tab and type color or some other preset, but nothing appears.
My version is the latest and I use C4D 2023. It only says "No results found".
The firewall is ok. Nothing blocked.
What happens?
NODE EDITOR.png (822.64 Kb)
Nov 30, 2024 01:31
What happens?
In the node editor menu you have to see the following picture:
Also make sure you have these files in the plugins folder, see the path in address bar.
Shortly the plugin should be correctly unpacked, the WinRAR archivator software is a good option for this.
Yes, the plugin is in the correct folder (the path is ok). But nothing apear in the node editor. :(
Dec 1, 2024 13:28
Please check how to install it correctly, I have recorded the steps on the Youtube video, make sure you don't miss something :) :
https://youtu.be/5CSpHjMrBKI
Also you may try to refresh the cache of nodes and other cached Cinema 4D items. Just remove the preferences folder, see the link below. This cache will be recreated on the next Cinema 4D launch, you will need to re-login with your account password when Cinema 4D will request for.
