Hello, I would like to ask about the preview of my material node editor. Only one shader ball appears. Thanks.
CentiLeo version 0.698
about material node editor
Nov 9, 2024 01:10
Hi Eric, but what do you want to do with this preview? What's the question?
Nov 9, 2024 01:49
I looked at your website and learned from it, and found that the content on your website is different.
Nov 9, 2024 11:44
Nov 10, 2024 17:59
Thank you very much
Nov 29, 2024 08:14
My Node editor does not show the presets. I click on the + tab and type color or some other preset, but nothing appears.
My version is the latest and I use C4D 2023. It only says "No results found". The firewall is ok. Nothing blocked. What happens? |
Nov 30, 2024 01:31
Also make sure you have these files in the plugins folder, see the path in address bar. Shortly the plugin should be correctly unpacked, the WinRAR archivator software is a good option for this.
Dec 1, 2024 08:29
Yes, the plugin is in the correct folder (the path is ok). But nothing apear in the node editor. :(
Dec 1, 2024 13:28
Also you may try to refresh the cache of nodes and other cached Cinema 4D items. Just remove the preferences folder, see the link below. This cache will be recreated on the next Cinema 4D launch, you will need to re-login with your account password when Cinema 4D will request for.
