Also publishing CentiLeo 0.483 for 3ds Max 2014-2017 like for C4D week ago!
Sorry, it took very long unexpected time, but it required to do so many little things in a complex system and many times the ongoing release was postponed. But now it's ready!
Download here:
Shaderball scene:
Light lister script by Ali Kavyani:
Change Log: cntlmax 0.483 alpha (2017 May 10)
[core] Material editor preview: much faster and nicer preview render.
[core] Each GPU is initialized with as much memory as needed by scene (unlike taking all free memory even for trivial scenes in CentiLeo 0.47).
[cntlmax] Slight reorganization of Material editor GUI (all SSS are placed in one tab, Translucency is also placed in a separate tab).
Known issues to be solved soon
Enjoy rendering with CentiLeo and share your opinion!
CentiLeo for 3ds Max 0.483 available (multi-GPU and efficiency improvement)
May 17, 2017 20:39
great update but it crash when rendering for all scene made under centileo.
May 18, 2017 07:49
Std question: what driver version, GPU (maybe several) and RAM size do you have? At what place does it crash?
May 18, 2017 10:22
it crash when i start the rendering. its not a probleme with old scene made with older version of Centileo, because when i make a new scene it crash also. If i use the IPR, the system remain bloqued, i must stop the process of 3DSMAX.
its peuraps my config, i use un laptop with a nvidia 650m (2go of ram GPU) and 8 go of ram. |
May 18, 2017 11:07
So the previous like 0.46-0.47 worked fine, right? Ok, it seems because of our hungry renderer for RAM. It is a bug in 0.48 that grabbed fixed 4GB for textures in Max, then 1GB for other CentiLeo needs and 1GB is grabbed by Max itself. After that it crashed because other things also grab memory. We are finishing 0.49 version with new shadow catcher and there will be a fix that will lower the initial grabbing of that 4GB. Will make it around 1.5 or 2GB.
But anyway the new recomendation is to have at least 12GB of RAM and 3GB of GPU mem for robust work. Why? All that out-of-core things require some minimum amout of memory needed for special data storage that allow out-of-core things to work. Starting from certain sizes of memory it works robust, e.g. 4GB GPU and 16GB RAM
May 28, 2017 05:38
after installing centileo changing on UI like toolbar and menus will reset after reopen 3dsmax. |
May 28, 2017 06:44
Please can you clarify what menus or toolbar do reset? We actually save/recover the open/close state of material rollouts in 3ds Max scene.
May 28, 2017 10:32
hope this help
May 28, 2017 11:50
Thanks, it's clear about a bug. Will try to fix it
May 29, 2017 13:23
May 30, 2017 16:59
Hi Kirill,
Tested by 0.462 ,0.471 and same problem as 0.483. |
