Also publishing CentiLeo 0.483 for 3ds Max 2014-2017 like for C4D week ago!
Sorry, it took very long unexpected time, but it required to do so many little things in a complex system and many times the ongoing release was postponed. But now it's ready!
Download here:
Shaderball scene:
Light lister script by Ali Kavyani:
Change Log: cntlmax 0.483 alpha (2017 May 10)
[core] Material editor preview: much faster and nicer preview render.
[core] Each GPU is initialized with as much memory as needed by scene (unlike taking all free memory even for trivial scenes in CentiLeo 0.47).
[cntlmax] Slight reorganization of Material editor GUI (all SSS are placed in one tab, Translucency is also placed in a separate tab).
Known issues to be solved soon
Enjoy rendering with CentiLeo and share your opinion!
