Finally we are releasing the 0.58 update of CentiLeo for 3ds Max 2014-2020. We appology for not updating so long, as we have radically changed the architecture to reduce the noise, improve speed and flexibility. It was a complex atomic work. The current release unites 0.56, 57 and 58 updates we had for CentiLeo +Cinema 4D plugin.
However, we have made great impovements, see the changelog and download for tests.
Download link:
Change Log: cntlmax 0.586 alpha (2020 January 30)
[cntlmax] Fixed problems when 3ds Max UI scheme is saved
[cntlmax] Fixed some mesh normal artifacts in rare cases
Change Log: cntlmax 0.585 alpha (2020 January 29)
[core] 5-10% rendering speedup
[core] Fixed shadow catcher weights in case of many light sources (makes shadows of different intensity per light source on the Matte/Shadow Catcher object).
[core] Fixed shadow artifacts in case of very small area lights.
[core] Bitmap file paths now support Unicode strings (not just English).
[core] Fixed camera Auto Focus in IPR ([AF] button).
[core] CentiLeo updated to CUDA 10.2.
Attention! Must Upgrade to:
Change Log: cntlmax 0.584 alpha (2019 December 31)
[core] Fixed z-fighting render artifacts for coplanar polygons in the scene, precision is improved.
[core] Fixed few rare crash-bugs.
[cntlmax] Installation instructions are changed a bit, read them again!
Change Log: cntlmax 0.583 alpha (2019 December 6)
[cntlmax] Fixed broken GUI layout for increased windows font size and high resolution monitors.
Change Log: cntlmax 0.582 alpha (2019 November 29)
[cntlmax] Added Ramp shader that colorizes the input b/w texture with other colors. The nodes of our ramp shader can be textured.
[cntlmax] Fixed scene units representation in all CentiLeo materials, shaders and lights.
[cntlmax] Focus distance in render settings can be animated.
[cntlmax] Initial 3ds Max Physical camera support (DOF focus distance, aperture size, bokeh). Next will add support for other things of Physical camera.
Change Log: cntlmax 0.581 alpha (2019 November 18)
Speedup
[core] Rendering speedup from 2x to up to 10x:
-Render iterations are around 2x faster almost always (base speedup);
-Render iterations become smarter and reduce the noise better for global illumination, in some cases it is required 2-4x less iterations to get same noise level as before. These improvements are best visible for interiors and night scenes especially for regions with dominated global illumination and lack of direct lighting.
-Mesh lights with complex shapes (more than few polygons) generate 3-4x less noise than before.
-The new algorithm should be always better and more robust than the previous one (less noise per iteration and faster iteration time).
-And there is no cache, no blur, no aditional settings, no additional memory consumption
![](http://centileo.com/bitrix/images/forum/smile/icon_cool.png)
Shader improvements
[core] New UVW Projection node supporting up to 4 UV mesh channels, spherical, cylindrical, cubic, flat, flat side, spatial and XYZ texture mapping coordinates. Texture coordinate system can be further manipulated (offset, scale, rotation) in the similar way to UVW Map modifier of 3ds Max. Offset, scale and rotation can be textured. Procedural texture coordinates are currently based on the object instances where material is assigned.
[core] New UVW Transform node which performs further manipulations on texture coordinates (UVW Projection can be an input for UVW Transform). Supported manipulations are offset, scale, rotation, pivot, rand offset, repetitions - these parameters can be textured.
[core] Extended CentiLeo Noise shaders with more noise types like Voronoi, Ronk, Ridged Multi-Fractal, etc.
[core] Bump mapping code totally changed (it also changes the look and scale of bump on older scenes). It has higher quality now and better combination with Normal Maps. Normal Maps now have all these flip R/G/B options.
[core] Fixed some problems with liquids inside glass in some modes.
[core] Faster bitmap cache generator (2x faster).
Mesh Lights and Multi-lights
[core] Mesh Lights support. This is implemented with an additional Emission property of CentiLeo material. Supports arbitrary (even out-of-core) geometry shapes for the light sources.
[core] Adaptive Multi Lights 10 times faster rendering for glossy reflection surfaces (faster rendering when there are a lot of light sources and glossy materials). Also bugfixed many issues in this area.
Bugfixes
[core] Fixed Windows 10 memory bug which could cause crashes in scenes with a lot of geometry and textures.
[core] Fixed artifact bug when SSS doesn’t follow motion blur.
[core] Fixed wrong clamping for 16+ bit bitmaps when used for displacement.
[core] Fixed some triplanar mapping artifacts.
[core] Fixed wrong bump mapping over displacement mapping (when bump and displace maps are different).
-Dirt shader;
-Absorption property of material;
-Directional/infinite light source;
-Adaptive noise-based image rendering (where pixels are no longer rendered when specified noise level is reached).
-May not initialize if AMD GPU is in your computer together with NVIDIA GPU.
-Very limited scene converter tool (Multi Sub-Obj Material, 3ds Max Bitmap, only diffuse color and diffuse texture of material are converted to CentiLeo)
Kirill
