We integrate with Cinema Node-based GUI for materials and shaders in CentiLeo 0.59 release!
It works for Cinema R21.115 and newer versions.
Maxon Cinema has very cool Nodes engine which we are happy to integrate with! It's a lot more powerfull than Slate editor in Max.
Currently there is no yet converter from old CentiLeo materials to new Node-based.
Note that in these new nodes we have organized materials a bit differently:
1) Emission is moved from CentiLeo Material to a separate own material
2) Displacement is also moved to the root Output Material.
Download here:
Attention! Must Upgrade to:
- Minimum Cinema R21 build is 115
Change Log: cntlc4d 0.593 alpha (2020 May 29)
- up to 2x less noise for some HDR images in interiors
- more stable noise structure for low sample count
- Cinema S22 support (for S22.016+ builds)
- Fixed const color profile interpretation of materials
Change Log: cntlc4d 0.592 alpha (2020 May 12) - currently for all R16-R21
- Fixed broken Absorption property
- Fixed bug for lost frames during animation rendering in PV
- Fixed bug with wrong geometry translation when IPR doesn’t account for some deformers (such as Surface Deformer and few others)
- Fixed few bugs which caused some crashes.
Change Log: cntlc4d 0.591 alpha (2020 April 08) - currently for R21 only
[core] Fixed broken Absorption property
[cntlc4d] Fixed bug for lost frames during animation rendering in PV
[cntlc4d] Fixed bug with wrong geometry translation when IPR doesn’t account for some deformers (such as Surface Deformer and few others)
[cntlc4d] Fixed few bugs which caused some crashes.
Change Log: cntlc4d 0.590 alpha (2020 February 24)
[cntlc4d] Native C4D Node-based GUI for CentiLeo shaders and materials! Only for Cinema 4D R21.115+.
- Dirt shader;
- Very limited material converter tool (diffuse color + texture of C4D material).
Kirill
