什么时候能够发布 正式版本,并且支持简体中文
中国用户 十分期待
Nov 5, 2021 04:31
他很棒的 产品 ,十分期待之后的使用,因为语言不通 使用起来有阻碍 ,希望能够在发布之后支持中文 ,
Nov 5, 2021 11:27
Kaki, thank you very much! I hope we will be able to make translation to Chinese at some point in the future. Of course it includes not only renderer interface translation, but also a future documentation. Also here on this forum it's better to use English language (even translated by computer) to better search the information.
多谢
Nov 7, 2021 20:47
The independently modified language files can be released, and interest lovers will actively translate them into their own language. Most simplified Chinese software is independently sinicized by interest lovers, and developers can also reduce the translation cost
Nov 8, 2021 01:40
dfnbnmb
Nov 8, 2021 13:26
Sure I will do this, there are Chinese files actually. Btw, it's possible to do even now for any use. He can just explore the res directory inside CentiLeo plugin, find *.str files - they describe all GUI words that we use for this or that module.
Also it's possible to translate Cinema/CentiLeo node space GUI for node materials/shaders. To do this one may open Resource Editor (type this in search string in top right corner of Cinema GUI). In this resource editor a user may find the CentiLeo nodespace database and go through all the materials and shaders to translate what is "Bitmap", what is "Ramp" and etc. There are not many, and things are quite easy.
Nov 14, 2021 00:28
Is the current version a test version? Or when can we release the official version? I am looking forward@ Kirgman
Nov 14, 2021 05:36
Hi Kaki! I think CentiLeo is already quite stable and has very good amount of features. Of course more features will be added. But I think it's rather stable
Nov 17, 2021 10:47
I have translated most of the texts into simplified Chinese. I will release a Chinese version on Bilibili these days
Nov 17, 2021 11:05
amazing,@Peirato Looking forward, I might as well leave the ID for a while, so that I can become the first viewer
Nov 17, 2021 19:49
Hi Peirato! Welcome to CentiLeo
Nov 18, 2021 11:03
@ Here is the video link: |
Nov 18, 2021 15:10
To edit the node materials there are few steps:
1. Open Cinema 4D in developer mode with Administrator rights. There are 2 options to do this: 1.1) Edit the properties of Cinema.exe shortcut. This shortcut of exe file can be found in windows task panel. In the properties of shortcut edit the launching object to this string:
It just changes the command line params to developer mode when you launch Cinema using the shortcut. 1.2) Alternatively, open CMD.EXE with Administrator rights and type the same string to CMD and press Enter keyboard button
2. Since you launch Cinema in developer mode create CentiLeo node material, right-click mouse on material node and click "Edit Resource". In the opened window you will see the interface of this particular node. 3. Change the language interface to Chinese in the node editor development (zh-CN) in the top left corner. 4. See the orange highlighted strings as on the image below to get the idea how to modify the strings that are used as translation. 5. The other CentiLeo nodes can be selected for editing in the top left corner in "Id" line (2 rows to the down from Language). 6. After you have finished your editing you should click to the top menu item Database and select "Save all Databases". 7. Your changes will be saved in the files in this folder (this is the CentiLeo plugin folder and it's internal "res\nodes\" subfolder)
8. The resulting .json files for R21 in our example after you have saved the Databases can be copied to the other plugin versions for R22-R26 or 2023. All .json files are the same for all Cinema versions for CentiLeo. 9. The other optional way to open Resource Editor is to click the "Search" icon in the very top right corner (under the close X button), and type "Resource Editor" there. In the opened window of resource editor select the language and the database "com.centileo.nodes.module" 10. The other language strings are stored in the folder:
In reality this is not complex. But the message looks large Maxon describes the launching of Resource editor with their documentation for programmers where you can see similar screenshots
Nov 21, 2021 09:33
Thank you very much for your help.
I will translate a better Chinese version in the near future, thank you again~ |
