How do you access the post-render settings so they save in the final rendered image?
It only affects my IPR images.
Post-render settings only apply to IPR image but not final render?
Hi, they should affect the final image. Do you have any post render settings override on the camera or no? I will check this on my tests
Post-render enabled was checked. I just realized that I was using a motion tracked 3D camera solve, and I did not have a centileo camera tag applied. However, when I switch to a centileo camera I also have no post-render settings being applied to the rendered image. And even using a centileo camera tag and overriding the post-render I still cannot get the render to use those settings. Also, I'm using multipass with diffuse and reflection passes. EDIT: I unchecked "Send RAW AOVs to Picture Viewer" and now it works. So if I want to use post-render settings I need to have that unchecked?
