I made a quick code to convert C4d Materials to centileo for a projects I'm working on..
the code just handels color and bump shaders that what I need for my project.. and its not complete working code beacose it's not handling expectations and errors ..etc.
| Code |
import c4d
# Get material's Vals
def MatConvertGet(material1):
# Get the material's Name
matname = material1.GetName()
# Get the material's shaders
shaderImg = material1[c4d.MATERIAL_COLOR_SHADER]
shaderCol = material1[c4d.MATERIAL_COLOR_COLOR]
shaderBumpImg = material1[c4d.MATERIAL_BUMP_SHADER]
Bump_stat = material1[c4d.MATERIAL_USE_BUMP]
shaderBumpVal = material1[c4d.MATERIAL_BUMP_STRENGTH]
Col_texture_path = ""
#Get the shader's texture path or color
if shaderImg:
Col_texture_path = shaderImg[c4d.BITMAPSHADER_FILENAME]
Bump_texture_path = ""
if shaderBumpImg:
Bump_texture_path = shaderBumpImg[c4d.BITMAPSHADER_FILENAME]
return {"matname" : matname,
"shaderCol" : shaderCol,
"Col_texture_path" : Col_texture_path,
"Bump_stat" : Bump_stat,
"shaderBumpVal" : shaderBumpVal,
"Bump_texture_path" : Bump_texture_path,}
# Create the centileo Clone
def CreatesCNTLmat(matname, shaderCol, Col_texture_path, Bump_stat, shaderBumpVal, Bump_texture_path):
c4d.CallCommand(58000, 1036659) # creat new CNTL material
material0 = doc.GetActiveMaterial() # Get the setected new material
material0.SetName("SNTL_"+matname)
# Color And Texture
material0[c4d.IDD_DIFFUSE_COLOR] = shaderCol
material0[c4d.IDD_REFL1_ROUGH] = 0.6
if Col_texture_path:
Shader1 = c4d.BaseShader(1036812)
Shader1[c4d.CNTL_XBITMAP_NAME] = "CColor"
Shader1[c4d.CNTL_XBITMAP_FILENAME] = Col_texture_path
material0.InsertShader(Shader1)
material0[c4d.IDD_DIFFUSE_COLOR_X] = Shader1
# bump map
material0[c4d.IDD_TOGGLE_BUMP] = Bump_stat
if Bump_stat:
material0[c4d.IDD_BUMP] = shaderBumpVal
if Bump_stat and Bump_texture_path:
Shader2 = c4d.BaseShader(1036812)
Shader2[c4d.CNTL_XBITMAP_NAME] = "BBump"
Shader2[c4d.CNTL_XBITMAP_FILENAME] = Bump_texture_path
material0.InsertShader(Shader2)
material0[c4d.IDD_BUMP_X] = Shader2
# Main function
def main():
# Get the active material
material1 = doc.GetActiveMaterials()
for mat in material1:
C4D_mat = MatConvertGet(mat)
CreatesCNTLmat(C4D_mat["matname"], C4D_mat["shaderCol"], C4D_mat["Col_texture_path"], C4D_mat["Bump_stat"], C4D_mat["shaderBumpVal"], C4D_mat["Bump_texture_path"])
# Update the document
c4d.EventAdd()
if __name__=='__main__':
main() |
so my question is how to replace the old materials by there centileo clones after creating them automatically using python of course
PS: I'm not a programmer by any means, I just know a little of python with some help from chatGPT
