Forums » Users » Ashrindy
Ok, please, can you post your GPU and PC specs pls? And R23 build version?
After extraction problem is excluded now the reason it doesn't show up can be either wrong plugin folder or R23 build version lower than R23.110
I've found the problem! Wasn't wrong importing, either PC specs being not good enough. I have R23.008.
Thank you for helping me troubleshoot this problem!
The normal files structure is like here:
Code
 pluginfolder/CentiLeoR23/CentiLeoR23.xdl64
pluginfolder/CentiLeoR23/library/centileo.dll
pluginfolder/CentiLeoR23/library/centileo_ipr.dll
pluginfolder/CentiLeoR23/res/ - a lot of files here
What was your archive extract program?
my archive extract program was WinRAR. The file structure is exactly the same.
ssjenforcer wrote:
Ashrindy wrote:
did you go to render settings and make centileo the renderer?
Hi ssjenforcer!
Thank you for trying to help! Problem is that it doesn't show up in the render settings, as said in the post.
It shows up only in nodespace.
Hi Ashrindy , please make sure to follow instructions on https://centileo.com/download/
Especially:
If CentiLeo doesn't show after installation
Update Cinema 4D build accordingly: R25.010+ S24.035+ R23.110+ S22.016+ and R21.115+ builds for latest Cinema versions.
Make sure supported GPU drivers are installed: NVIDIA Game Ready Driver 441.87+ or NVIDIA Studio Driver 441.66+ from here
So the drivers should be up-to-date and R23 build version should be at least R23.110 or newer. Do you use Nvidia GPU?
Hi Kirgman!
Thanks for your quick response!
I have followed all of the instructions very precisely although still nothing showing up.
My drivers and R23 are very up to date, and yes i do use nvidia gpu.
