Apr 13, 2022 09:28
Apr 13, 2022 09:49
Hi Ashrindy, please make sure to follow instructions on
Especially:
Apr 13, 2022 21:48
- Apr 13, 2022 21:49
Apr 14, 2022 03:36
Thanks for your quick response! I have followed all of the instructions very precisely although still nothing showing up. My drivers and R23 are very up to date, and yes i do use nvidia gpu. |
Apr 14, 2022 03:37
Thank you for trying to help! Problem is that it doesn't show up in the render settings, as said in the post. It shows up only in nodespace. |
Apr 14, 2022 11:03
Ashrindy, pretty strange... Ok, can you screenshot the folder you have copied CentiLeo plugin to?
One thing I have in mind is that it could probably be extracted from the archive in a wrong way and violating the structure of plugin components. Have you used WinRAR to extract the downloaded archive or something else?
Apr 14, 2022 11:06
The normal files structure is like here:
What was your archive extract program?
Apr 14, 2022 14:15
my archive extract program was WinRAR. The file structure is exactly the same. |
Apr 14, 2022 15:07
Ok, please, can you post your GPU and PC specs pls? And R23 build version?
After extraction problem is excluded now the reason it doesn't show up can be either wrong plugin folder or R23 build version lower than R23.110
Apr 15, 2022 03:59
Thank you for helping me troubleshoot this problem! |
Apr 15, 2022 10:44
These small numbers of build version are hardly noticeable but can create the issues. Although I am quite surprised you have so low version. In fact R23.110 is one of the early official releases. You probably use some early build from Maxon beta program.
