Nice updates.
Dec 10, 2018 15:16
Dec 19, 2018 15:09
Dec 28, 2018 10:42
[cntlmax] Added 3ds max 2019 support. [cntlmax] Fixed crash bugs for animation rendering of objects with Greeble modifier. Will update CentiLeo for 3ds Max on 0.58 release with new shaders and render speed optimizations.
Feb 7, 2019 06:34
//Daniel |
Feb 7, 2019 15:51
As for RTX rays acceleration hardware feature - not supported. At the current state of RTX ray acceleration feature - it may be not compatible with some current and future CentiLeo features. Btw, I will update CentiLeo for Max at the next 0.58 release
Feb 16, 2019 03:50
Thanks for latest updates.well done
Feb 21, 2019 14:27
Not sure if its the 4k resolution or something else. Best Daniel |
Feb 22, 2019 05:10
Feb 22, 2019 10:23
Thanks, good to know!
//Daniel |
Mar 15, 2019 04:42
Mar 20, 2019 11:23
Jun 4, 2019 05:34
really longing for an update now
//D |
Jun 4, 2019 15:40
Jun 5, 2019 04:54
Great job guys keep up the good work
