Nice updates.
[cntlmax] Added 3ds max 2019 support. [cntlmax] Fixed crash bugs for animation rendering of objects with Greeble modifier. Will update CentiLeo for 3ds Max on 0.58 release with new shaders and render speed optimizations. |
//Daniel |
As for RTX rays acceleration hardware feature - not supported. At the current state of RTX ray acceleration feature - it may be not compatible with some current and future CentiLeo features. Btw, I will update CentiLeo for Max at the next 0.58 release ![]() |
Thanks for latest updates.well done
Not sure if its the 4k resolution or something else. Best Daniel |
CentiLeo Light - is the right choice. It unites the other lights. But other (depr) lights are "deprecated". They will be removed, so they should be avoided. |
Thanks, good to know!
//Daniel |
really longing for an update now
![]() //D |
Great job guys keep up the good work
