We can finally release an update CentiLeo 0.55 for Cinema 4D with new displacement mapping engine. There work was so long because there was a lot of R&D and new algorithms were created to make DM efficient.
We have opted to make DM based on geometry pre-tesselation because we want it to support arbitrary shader networks as input and to make vector displacements too. Both these things are impossible without pre-tesselation. And with this fact many problems may happen like huge poly-counts, screen adaptivity artifacts, not so fast tesselations and renderings. However, we have solved many of these. Btw, there are still some drawbacks and vector displacements are not yet added, but we will fix that at later stage.
Download link (site registration required):
Change Log: cntlc4d 0.552 alpha (2018 June 16)
Change Log: cntlc4d 0.551 alpha (2018 June 12)
[core] Added overall displace scale and waterlevel parameters.
[cntlc4d] Fixed wrong texture rotation displayed in the viewport.
[cntlc4d] Fixed GPU priority toggling in IPR.
[cntlc4d] Focus distance data from CentiLeo camera tag is automatically moved to corresponding field of the camera object.
Change Log: cntlc4d 0.550 alpha (2018 June 7)
[core] Displacement Alpha map is used as the mask of displacement values of the current material which can be useful when several materials are stacked as layers in Cinema 4D.
[core] Added support of 16/32 bit bitmaps for Displacement.
[cntlc4d] CentiLeo camera Depth of Field now listens for native C4D camera focus distance property with proper updates when changed from C4D Editor or CentiLeo IPR.
[cntlc4d] Fixed various rare visual bugs, e.g. a bug that made visible artifacts at low FOV.
CentiLeo for Cinema 4D 0.552 available - displacement mapping!
Jun 7, 2018 15:43
i just test a sample scene with displacement take 00.50 seconds and without displacement take 00.33 seconds . loading and memory it is so awesome .
Jun 7, 2018 15:52
Displaced version is slower than without it just because it has more polygons. More polygons for same scene produce slightly slower rendering. But if you model everything with same polycounts the will be same situation
Jun 16, 2018 08:31
In the past there were subtle waves on high-frequency displacement surfaces during animated walktrhough even when Edge size is 0.5 pixels (and Adapt to pixels ON). Now this artifact is removed for Edge size equal to 0.5 pixels. But still need to improve things for Edge size = 1 pixels with a more sophisticated aproach. Btw, there was no wave problem during any animation for Edge size in world units (with pixel adaptation disabled). However, if tesselated in this mode there could be more polygon data generated than for adaptive pixel mode.
